I've been fiddling with this old pic for over a month now,
and I need to start something new, but I thought somebody
might like it.
I think it's sufficiently different (better?) to merit a re-post.
The walls are my own terracotta-ish texture, The sun, Venus
and Saturn are my own models, Earth and the moon are
uv mapped, Mars is a simple projection of an image onto
a sphere.
I found much better, more accurate renderings of Saturn's
rings on the web but I still kind of like mine (they're done
with media, a radial density map and type 5 scattering).
The oil painting is by Joseph Wright of Derby, 1734-1797.
http://www.mezzo-mondo.com/arts/mm/wright/wright.html
"A Philosopher Giving that Lecture on the Orrery in which
a Lamp is put in place of the Sun" (1766)
Bill Hails
Download 'orrery-med.jpg' (144 KB)
Preview of image 'orrery-med.jpg'
Excellent !
_Light_Beam_ wrote:
> Excellent !
Thanks!
I've learnt a lot doing it.
I'm not really happy with it, from a compositional point of view,
too many distractions, like the bookcase and the arches,
but removing those makes the setting dull, so I'm at a loss as
to what to do to improve it.
best put it away for a while and start something else :-)
Bill Hails
I really like it too, it must be a lot of work.
Maybe some focal blur, it would show better what to look at and add some
more realistic looking to the image.
I would also improve a bit the book at first plane, scaling down a bit
the crakle normal (+ turbulence 0.1) so that it's not so obvious that it
is the all purpose crackle pattern and add thickness to the cover's
corners and give them a leather texture.
Yes, I understand that, it seems that working too much on the same image
drains out all artistic energy.
JC
I just remember I found this page yesterday :
http://www.wozzeck.net/images/DoF_fr.html
It's a very interesting focal blur settings macro by Francois Dispot.
It's in french but the zip is down the page. It's four years old, but I
found it yesterday, probably everybody knows it, but it was a discovery
to me. :-))
JC
> JC
Thanks, yes quite a lot of work, evenings and weekends.
It's a thought, but the painting on the wall is at the same distance as the
bookcase, and I want the painting to stay sharp. Maybe a slight ground
fog might work.
Agreed. I hadn't really realised how obvious the crackle is, and it doesn't
really look like leather either, just a first approximation.
The corners are already thicker than the book, but only by a tiny amount.
I can increase that.
> JC
Bill Hails
Brilliant work!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Hi Bill!
Looks good, but the lighting needs improvement: your sun is an
extended light source, so
- no shadows of the bars carrying the planets should be visible
on the desk
- the disk below the sun (on the desk) should be free of shadows
- the shadow of the book in the foreground should be very soft
- more than a half sphere of the planets should be lit (esp. Venus)
- where is the shadow of the desk on the ground/walls?
Probably the best solution for the lighting is radiosity, but I
haven't worked with that yet.
I also would like so see some indication of how the planets and
the sun are floating above their supports: magnetism? transparent
material? riding on air streaming out of nozzles below the planets? electrostatic
repulsion? magic?
On the desk, between the signs for Pisces and Aries, a rectangular
area looks less "dusty" than the rest of the desk. Is that the
intended meaning?
As a last point I suggest to drastically reduce the camera's angle.
At the moment this angle introduces distortions to the picture
(visible esp. at the painting) which are correct for a viewing
distance of only some centimeters, but look wrong for normal
viewing distances.
If you put it away for a while: not too long, please; I'd like to
see the next steps of its evolution!
Sputnik
H Frank, thanks for your comments.
> Hi Bill!
> on the desk
I agree, but an area light introduces too vague a shadow on the
rings of saturn. I'd pinned my hopes on a parallel light, but that
requires a pont_at statement :-(
I was trying to avoid letting the planets look too much "in the room"
as opposed to "in space", the harsh shadows on Saturn's rings
help there, I think.
same point vs area light issue, maybe a fairly tight area light would do it.
I made the table and planets except Saturn, and even the support for
venus no_shadow, otherwise it looks a mess: *lots* of shadows
all over the place. I'd love to think that the next povray release might
have a modifier for no_shadow that specifies a percentage.
I have radiosity turned on, but that's just to soften the colours.
I've made a few attempts at radiosity without conventional lighting
on this pic but the sun needs lots of output, I'm not sure radiosity
alone can do it.
> electrostatic repulsion? magic?
Magic. :-)
I kind of disagree on this pont, I think the lack of connection is a sort
of statement in itself, the supports are all dead center on their planets
after all.
> intended meaning?
well spotted, it's meant to show a previous position of the book.
I should really add some smearing in the dust to the current
position, and should maybe up the density of the dust a touch.
> viewing distances.
earlier versions had a much tighter angle, but the addition of that
set of columns receding into the distance looked bad, so the
current angle is a compromise.
Maybe it's not an optimal one.
Thanks!
I was really getting a bit tired of it, but I can feel a fresh wave
of enthusiasm coming on. I think I should lie down :-)
> Sputnik
Bill Hails
Rick [Kitty5] wrote:
> Brilliant work!
Thanks!
Bill Hails
