POV-Ray : Newsgroups : povray.binaries.images : Not a dodecahedron (wallpaper) Server Time
11 Sep 2025 07:22:11 EDT (-0400)
  Not a dodecahedron (wallpaper) (Message 1 to 4 of 4)
Subject: Not a dodecahedron (wallpaper)
Date: 24 Sep 2003 14:05:45
Message: <3f71dcf9@news.povray.org>
I was inspired by Andy Cocker's "Max Trace Magic", so I made this. What you are
looking at is -not- a dodecahedron, even though it looks a lot like one. The
camera is inside a reflective tetrahedron, and there are 4 cylinders protruding
from the center of each face of the tetrahedron and meeting in the middle. The
small image shows you the scene from a different point of view with the
reflections turned off.
The illusion of a dodecahedron is caused by the fact that the angles between
faces in a tetrahedron is nearly the same as the angle between points on a
dodecahedron, so the reflections form an image that nearly looks like a
dodecahedron.
Tek
http://www.evilsuperbrain.com
Download 'diamond mirror.jpg' (149 KB) Download 'diamond overview.jpg' (5 KB)
Preview of image 'diamond mirror.jpg'
Preview of image 'diamond overview.jpg'
Subject: Re: Not a dodecahedron (wallpaper)
Date: 25 Sep 2003 12:19:39
Message: <3f73159b@news.povray.org>
Cool idea, you used colored mirrors, didn't you ?
Did you try with a rounded tetrahedron ? That would give smoother
transition from one plane to another ...
JC
> dodecahedron.
Date: 25 Sep 2003 14:41:25
Message: <3f7336d5@news.povray.org>
Yes I did.
I thought the same thing, though I couldn't get the right effect. Simply
smoothing off the corners wouldn't work because the 2 bits of the dodecahedron
that nearly meet up are actually reflections in completely different directions
(any 2 mirrors in the tetrahedron are at an angle sharper than 90 degrees), so
smoothing between them would get a reflection of lots of other things between
the two.
So instead I replaced each face of the tetrahedron with a sphere, but after much
adjusting I couldn't line up the edges exactly. However I did stumble across
this much more interesting pattern (which is now my desktop wallpaper!) :)
Tek
Download 'diamondtree.jpg' (111 KB)
Preview of image 'diamondtree.jpg'
Date: 26 Sep 2003 04:16:05
Message: <3f73f5c5@news.povray.org>
Woowww, that does it, nice view !
> Yes I did.
> the two.
