POV-Ray : Newsgroups : povray.binaries.images : MayaFur v1.0 Server Time
16 Jul 2026 04:30:47 EDT (-0400)
  MayaFur v1.0 (Message 11 to 19 of 19)
Subject: Re: MayaFur v1.0
Date: 26 Aug 2003 00:00:59
Message: <3f4adb7b@news.povray.org>
I don't see the original code for this example, but you might try something
like this as a starting point:
#declare length=1;
#declare base_width=0.05;
#declare tip_width=0.01;
#declare segments=50;
#declare base_curl=0;
#declare tip_curl=0;
#declare scraggle=0.75;
#declare scraggle_freq=20;
#declare save_name="scragglehair.inc"
#declare scraggle_seed=723562;
#declare tti=5;
SingleHair(length, base_width, tip_width, segments, base_curl, tip_curl,
scraggle, scraggle_freq, save_name, scraggle_seed, tti)
A quick render with these settings gave me the attached image.
Doug Eichenberg
www.getinfo.net/douge
dou### [at] nlsnet
Download 'MayaFurDemo.jpg' (166 KB)
Preview of image 'MayaFurDemo.jpg'
Date: 26 Aug 2003 03:33:41
Message: <3f4b0d55$1@news.povray.org>
Looks like a dog who got a pretty serious electric shock!
I wonder though, if all these triangles are copies of one mesh because they
look very similar, in this image.
It's nice.. Probably the best fur macros I've ever seen for POV.. I'll hope
to use this somehow. :o)
Regards
Hugo
Date: 26 Aug 2003 04:20:51
Message: <3f4b1863$1@news.povray.org>
After some tries, I think that improving memory use and rendering time
could be a priority for the MayaFur.inc
I tried the example yesterday night and on my XP2800 with 1Go I fell
down to 10PPS (Quality set to 1) !
Apart from that, the packaging of the include is really great with good
explaination and schemas.
JC
Doug Eichenberg wrote:
> The MayaFur.inc file I have been working on is ready, and can be downloaded
> here:
> http://www.getinfo.net/douge/downloads.htm
> Basically, it is a set of macros for POV that mimics the way fur is done in
> Maya.  More info can be found in povray.news-submissions, but I wanted to
> include a sample render here for those that haven't seen it.
> Doug Eichenberg
> dou### [at] nlsnet
Date: 26 Aug 2003 07:22:26
Message: <3f4b42f2$1@news.povray.org>
The thing to understand is that if you want a reasonable render time you
have to turn off TTI and use a standard POV texture.  It would help to turn
off (or at least tone down) the radiosity too.  That demo image uses pure
radiosity lighting and TTI texturing, which takes a lot of memory and
resources.
Doug Eichenberg
dou### [at] nlsnet
JC (Exether) <no### [at] spamfr> wrote in message
news:3f4b1863$1@news.povray.org...
> JC
downloaded
> > here:
in
to
> > Doug Eichenberg
> > dou### [at] nlsnet
Date: 26 Aug 2003 07:30:48
Message: <3f4b44e8@news.povray.org>
OK, I'll try to change the settings, maybe you should make your example
auto-tunable, because it's a bit frightening at first.  :-)
JC
> resources.
> Doug Eichenberg
> dou### [at] nlsnet
>>JC
> downloaded
>>>here:
> in
> to
>>>Doug Eichenberg
>>>dou### [at] nlsnet
Date: 26 Aug 2003 08:01:13
Message: <3f4b4c09@news.povray.org>
Is it just me or are there "bald" patches in places on this image?
Date: 26 Aug 2003 17:50:56
Message: <3f4bd640$1@news.povray.org>
Yes, but that's because I turned down the hairs_per_unit to a really low
number, since I was only testing scraggle.
Doug Eichenberg
dou### [at] nlsnet
Neonux <neo### [at] softhomenet> wrote in message
news:3f4b4c09@news.povray.org...
Date: 26 Aug 2003 17:53:00
Message: <3f4bd6bc$1@news.povray.org>
Yeah, with the demo scene, I was trying to max out the settings on a low-end
machine... p3 700MHz with 256meg.  The fact that I could get 160,000 hairs
with pure radiosity lighting and triangle texture interpolation seemed
pretty good to me on that machine :P
Doug Eichenberg
dou### [at] nlsnet
JC (Exether) <no### [at] spamfr> wrote in message news:3f4b44e8@news.povray.org...
> JC
turn
pure
> > resources.
> > Doug Eichenberg
> > dou### [at] nlsnet
> >>JC
> > downloaded
> >>>here:
done
> > in
> > to
> >>>Doug Eichenberg
> >>>dou### [at] nlsnet
Date: 26 Aug 2003 23:10:41
Message: <3f4c2131@news.povray.org>
Okay, thanks. I have to figure out hot to turn that into a more abstract
shape, but that should be a fun exercise.
Thanks again,.
D.
"Doug Eichenberg" <dou### [at] nlsnet> wrote in message
news:3f4adb7b@news.povray.org...
something
> #declare length=1;
> #declare tti=5;
> Doug Eichenberg
> dou### [at] nlsnet
