POV-Ray : Newsgroups : povray.binaries.images : Planet Earth rendered Server Time
9 Nov 2026 15:44:38 EST (-0500)
  Planet Earth rendered (Message 21 to 27 of 27)
<<< Previous 20 Messages Goto Initial 27 Messages
Subject: Re: Planet Earth rendered
Date: 25 Jul 2003 09:53:13
Message: <3f213649@news.povray.org>
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:3f20353c@news.povray.org...
> Fernando Gonzalez del Cueto wrote:
> > Are the heights on a real scale? I saw Africa-Europe image and it seems
to
> > me that the elevations are exagerated, but perhaps I have a wrong
> > intuition.
> As explained in the text above the images, the height (and the atmosphere)
> is scaled by a factor of 30.
Only 30?  Looks something more like 10,000 to me.  They say the earth, if
shrunken down, would be more smooth than any common man-made sphere.
> Otherwise Earth would be boringly flat ;)
I agree, and you do have artistic license for scaling, including your
extremely thick atmosphere.
> Wolfgang
Date: 25 Jul 2003 13:24:36
Message: <3f2167d3@news.povray.org>
>> atmosphere) is scaled by a factor of 30.
Look: The atmosphere is 20km, scaled by factor 30 yields to 600km.
Earth has a radius of 6368km (don't mind the last digit) which is
about 1/10th of the atmosphere. Looking at the image that seems
plausible...
Ok, then I'll use my "license" :)
Wolfgang
Date: 25 Jul 2003 21:33:19
Message: <3f21da5f$1@news.povray.org>
10000?? A mountain, only 1.3 km high, scaled by this factor, would then
be higher than the earth's equatorial diameter!
This shrunken earth would then be a very tiny sphere:
   Diameter of earth = 12756 km
   Height of Mt. Everest = 8.850 km
   Depth of Marianas trench = 10.924 km
Thickness of the traces of a standard printed circuit board = 0.035 mm
These traces are man-made and are *easily* felt with the fingertips.
Shrinking the earth by approx. 1/253000000 gives
   Diameter of earth = 5 cm (2")
   Height of Mt. Everest = 0.035 mm
   Depth of Marianas trench = 0.043 mm
Shrinking the earth by approx. 1/312000000 gives
   Diameter of earth = 4.1 cm
   Height of Mt. Everest = 0.028 mm
   Depth of Marianas trench = 0.035 mm
Although neither Mt. Everest nor Marianas trench have vertical walls,
even a 5-cm-earth would have a feelable Mt. Everest and Mariana trench.
But 35 micrometers are far from the smoothest man-made sphere; the
most accurate sphere probably is this:
http://www.tip.csiro.au/IMP/Optical/spheres.htm
Enlarging this to earth-size, we get
   Diameter =    9.4 cm -> 12756 km
   Total error =  50 nm -> 6.79 m (not km!)
   Roughness   = 0.2 nm -> 37.6 cm
Or the other way:
   Diameter of earth = 0.032 mm (!)
   Height of Mt. Everest + Depth of Marianas trench = 50 nm
So "more smooth than any man-made sphere" is wrong by two to three
orders of magnitude (depending on the diameter, of course).
   Sputnik
Date: 28 Jul 2003 16:01:13
Message: <3F259ED2.42733308@tiscalinet.de>
High!
Wolfgang Wieser schrieb:
  The large volvano is Olympus Mons -- said to be the highest volcano in
  the solar system: it is 24km high and measures 550km across.
  The large canyon system is called Vallis Marineris: it extends
  over 4000km and is up to 7km deep.
No, the latter is not true - there are some areas in the large southern
impact basin Hellas Planitia which are even about 8,000
metres below average elevation!
See you in Khyberspace -
http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Home-made electronic music:
http://home.arcor.de/yadgar/music/Transrapid.mp3
Yadgar
Now playing: Total Banane (Zoff)
Date: 28 Jul 2003 17:51:08
Message: <3f259acb@news.povray.org>
If I understand you correctly, then you just explained that there
is a region on Mars called "Hellas Planitia" which is 8 km "deep" (?)
That's interesting... maybe you know the longnitude and latitude?
BTW, I don't see why my above statement is "not true".
A close-up rendering of Vallis Marineris is available here:
http://www.cip.physik.uni-muenchen.de/~wwieser/render/img/mars/
Wolfgang
Date: 29 Jul 2003 05:41:35
Message: <3f26414f@news.povray.org>
Wolfgang Wieser wrote:
> Unfornunately, the link is dead and half an hour searching the net
> did not reveal it...
2min searching the ftp server revealed:
ftp://ltpftp.gsfc.nasa.gov/projects/tharsis/MOLA/GRIDS
   Matthias
Date: 31 Jul 2003 04:47:17
Message: <3f28d790@news.povray.org>
Yeah... because that IS the dead link I mentioned.
Fortunately, it seems that the host was only temporarily down
because I was able to get that file today.
Thanks for pointing that out.
Wolfgang
