POV-Ray : Newsgroups : povray.binaries.images : Grassy Julia, Final Server Time
13 Jul 2026 20:06:52 EDT (-0400)
  Grassy Julia, Final (Message 11 to 13 of 13)
Subject: Re: Grassy Julia, Final
Date: 25 Jul 2003 18:34:07
Message: <3f21b05f$1@news.povray.org>
"Tony LaVigne" <ton### [at] xenomechanicscom> wrote in message
news:web.3f2165ea2acdf50fd97cd3e00@news.povray.org...
> Very nice rendering.
> How did you model the water surface?
> If the code for it is available it would be appeciated.
> Thanks
> Tony
Sure thing. Basically the sea is a flat plane with a granite texture used as a
normal map, and some realistic reflection settings. I've also added concentric
ripples to the surface around the base of my object, and flattened the surface
in the distance to prevent unpleasant noisiness near the horizon.
Here's the full source for the ocean effect:
//ocean
#declare f_Ripple =
 function ( d ) {
  sin(d*80)/(d*d)
plane {
 y, -.8
 material {
   pigment { rgb <.3,.5,.5> filter 1 }
   finish { diffuse 0 reflection { 0.05, 1 falloff 5 } conserve_energy }
   normal {
    function {
     .5+
     (1/((x*x+z*z)/pow(30,2) + 1))* //exp(-(x*x+z*z)/pow(50,2))* //
      -.1 * f_granite(x,y,z)
      + .002*f_Ripple( sqrt(x*x+z*z)-.3 ) //rippples from base of object
    } 1
    translate <.15,0,-.4>
  } //texture
  interior {
   ior Water_Ior
  } //interior
 } //material
Tek
http://www.evilsuperbrain.com
Date: 26 Jul 2003 00:50:02
Message: <web.3f2207492acdf50f5de5b4510@news.povray.org>
Tek
Your the best.  I love this water surface.  To render your code on my system
I had to make two modifications, the first was to include the f_granite
file before it was called with...
#include "functions.inc"
and the 2nd was to sub "Water_Ior" with "`1.33"
I need to ask one more question and I'll post it soon,
again, thanks for all the insights,
Tony
xen### [at] xenomechanicscom
Date: 26 Jul 2003 11:55:27
Message: <3f22a46f$1@news.povray.org>
Oh yes, for Water_Ior you'll want #include "consts.inc".
Tek
news:web.3f2207492acdf50f5de5b4510@news.povray.org...
> Tek
> Tony
