POV-Ray : Newsgroups : povray.binaries.images : Indoor Radiosity Experiments (24kb + 25kb + 25kb) Server Time
16 Jul 2026 09:16:20 EDT (-0400)
  Indoor Radiosity Experiments (24kb + 25kb + 25kb) (Message 11 to 20 of 20)
Subject: Re: Indoor Radiosity Experiments (25kb)
Date: 13 Jul 2003 08:03:11
Message: <3F114A7F.36AB7A04@gmx.de>
"Tim Nikias v2.0" wrote:
> Well, here's the pic I've forgotten to attach...
> Notie that all those artifacts get smoothened
> out later when using a higher error_bound.
This image strongly indicates a not high enough max_trace_level.  For
radiosity with reflection and refraction it is usually advisable to turn
off reflection and refraction for the pretrace.  For this you usually need
three renders:
1) generate photons with correct finishes/interiors
2) generate radiosity data without reflection and refraction.
3) do the final render using both previously generated data files.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Subject: Re: Indoor Radiosity Experiments (24kb + 25kb + 25kb)
Date: 15 Jul 2003 14:30:55
Message: <3f14485f@news.povray.org>
Tim Nikias v2.0 wrote:
> Additionally, it might be of interest to know that using
> actual lightsources gives sharper shadows (though using
> area-lights to get soft shadows is a must for realistic lighting,
> somewhat paradox). BUT, it must be said that shadows
> produced by pure radiosity lighting are VERY soft.
It really depends on the circumstances. With a sufficiently low
error_bound and high count, and the right environment, I have seen
radiosity produce some pretty sharp shadows. The "problem" is that the
scenes where radiosity typically has the greatest obvious impact vs.
normal point lighting are those where there are large lit areas (skies,
well-lit rooms with white walls, etc) and naturally when light is coming
from everywhere, you're going to have some pretty soft shadows.
If you want sharper shadows in such a scene, you'll have to set it up so
that the "main" light sources in the scene are much brighter than the
lit objects around them (or else reduce the radiosity brightness, which
provides much the same effect). I think you'll see this as you start
playing with outdoor scenes with full sun, although an indoor
environment could also work if you're using a bright, naked light bulb
for lighting.
-Xplo
Date: 15 Jul 2003 14:52:50
Message: <3f144d82@news.povray.org>
Well, not much to say to that, you've got straight
A's on your radiosity-examn. :-)
Seriously though: I was just analyzing indoor scenes
with pure radiosity, especially scenes where the lightsource
is more or less a lightbulb or something similiar. Shadows
produced by those are very soft, as said before.
But sure, with the right settings, one could get crisper
shadows. Still, I'd go so far and say that for the majority
of scenes where radiosity is used indoors, shadows
produced thereby are very soft.
Tim Nikias v2.0
> for lighting.
> -Xplo
Version: 6.0.501 / Virus Database: 299 - Release Date: 14.07.2003
Date: 17 Jul 2003 12:07:46
Message: <3f16c9d2@news.povray.org>
As they probably should be.
Next time you're in a room with a radiosity-ish light source (say, a
lamp with a large shade that blocks out most of the direct light) take a
look at the shadows. My own room is like that, and looking around, even
objects a dozen feet from the lamp and a few inches from the wall have
rather soft shadows.
I doubt you have any viable pure radiosity scenes that accurately
simulate a naked lightbulb in a room; the lightbulb would be so small
that even with count 1600, the vast majority of those tests would miss
it entirely, resulting in massive artifacting; increasing recursion to 2
or 3 (as appropriate for such an environment) would only increase this,
as would setting error_bound low enough to make the radiosity capable of
producing sharp shadows (say, .1 or less).
If a method is found and implemented to allow significantly higher count
values, the naked light scene would make an interesting experiment.
However, AFAIK, no one is working on it (and I have no ideas).
-Xplo
Date: 26 Jul 2003 00:22:07
Message: <1qtabcxlgsegc.znwzdjl4civm.dlg@40tude.net>
On Sun, 13 Jul 2003 11:50:52 +0200, Apache wrote:
> ratiosity will take media into account with "media on". But what about the
> other way around: media taking ambient light sources or diffused light into
> account?
Radiosity depends on 2 dimensional surfaces by nature making it impossible
(someone prove me wrong!) to render multiple scattering with it. It IS
possible to render multiple scattering with photons so I stand by my
opinion that radiosity should be done in and diffuse reflection should be
calculated using photons.
PS. Hey everyone! It's been a while since my last post but I haven't given
up. ;-)
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
Date: 26 Jul 2003 07:04:57
Message: <3F226058.78DA276@gmx.de>
I am not really sure what you are talking about here but i have the
impression that you got something seriously wrong.
Date: 26 Jul 2003 20:15:21
Message: <1ca7m5lzrlp1n$.dkwxaszj374j.dlg@40tude.net>
> Christoph
What I meant to say was that, by my understanding, the radiosity system is
incompatible with multiple scattering. I then went on to ramble how I
believe it should be replaced with photon mapping.
Date: 27 Jul 2003 07:38:46
Message: <3F23B9C6.5C443213@gmx.de>
What makes you think this?
Date: 28 Jul 2003 23:23:49
Message: <5ktm3bunh3he$.930r896w5f2k.dlg@40tude.net>
> Christoph
I could easily be mistaken, but AFAIK, radiosity takes only a few samples
for many pixels (count) to speed up the render process and when finding the
colour for a given pixel, finds the nearest calculated samples
(nearest_count) on the same surface and does a weighted average. This is
kinda hard to do when there are no surfaces (3d media). If I'm wrong, just
say so and I'll shut up. ;-)
Date: 29 Jul 2003 06:21:48
Message: <3F264ABB.C579C193@gmx.de>
Ah, so you don't mean there is a problem for radiosity taking into account
media but media being illuminated by diffuse light.  This is indeed not
handled in POV-Ray radiosity at the moment - it is not impossible to do
this with monte carlo radiosity though.
It all comes down to an effect quite rarely needed (since diffuse light
rarely creates a very clearly defined effect on media) and that would be
quite slow to compute.
