POV-Ray : Newsgroups : povray.binaries.images : They Gather On the Plains Server Time
21 Jun 2026 18:41:32 EDT (-0400)
  They Gather On the Plains (Message 1 to 10 of 10)
Subject: They Gather On the Plains
Date: 4 Jul 2003 17:03:42
Message: <3f05ebae@news.povray.org>
Hi all,
These 2 images started life as a 'let's just start and see where we end up' subpatch
modelling
session in Lightwave. In my search for a suitable simple environment to view my WIP's,
I got
sidetracked into trying to output HDR's from Terragen using Sean O'Malley's
Cube2Cross.exe and
HDRShop.
So, here's where I ended up. Dunno what the 'shapes' are, or what they are doing for
that
matter.
I just used a little post-processing (the trusty blurred image set to 'screen').
What do you think?
All the best,
Andy Cocker
Download 'They Gather On The Plains - Bliss Version.jpg' (25 KB) Download 'They Gather On The Plains - Sunset Version.jpg' (27 KB)
Preview of image 'They Gather On The Plains - Bliss Version.jpg'
Preview of image 'They Gather On The Plains - Sunset Version.jpg'
Subject: Re: They Gather On the Plains
Date: 4 Jul 2003 17:21:36
Message: <3f05efe0@news.povray.org>
Wow..... this is really impressive stuff.
I think you should render it in a much larger image size!
Date: 4 Jul 2003 20:52:20
Message: <3f062144$1@news.povray.org>
I like, I like!
Date: 5 Jul 2003 07:26:43
Message: <3f06b5f3$1@news.povray.org>
Anything POV related here? You mention Lightwave and Terragen. Anyway, what
I would like to see is some macros to set up enviroments in POV that renders
like Terragen. Having it all under one roof is much more efficient,
especially in animations, and besides I'd like to see another victory for
POV.
Hugo
Date: 5 Jul 2003 08:56:30
Message: <3f06cafe@news.povray.org>
"Hugo Asm" <hua### [at] post3teledk> wrote in message news:3f06b5f3$1@news.povray.org...
> POV.
Well, it's rendered in POV. Is that enough? ;-)
All the best,
Andy Cocker
Date: 5 Jul 2003 11:05:50
Message: <3f06e94e@news.povray.org>
Atmospheric!
I like the way the sunlight blurs over the outlines of the things in the
middle. Is that a post-process effect?
Date: 6 Jul 2003 16:27:53
Message: <3f088649@news.povray.org>
"Luke" <Luk### [at] hotmailcom> wrote in message news:3f06e94e@news.povray.org...
> Atmospheric!
Yes, it is. It's quite simple (after it was explained to me by somebody here... ABX
IIRC). In
Photoshop or equivalent, duplicate the background layer, then adjust the contrast
(using
Curves) to give white in the areas you wish to 'bloom', and black in all the others.
Then use
a gaussian blur on the new layer (I used a value of 8) and finally, set the layer type
to
'Screen'.
All the best,
Andy Cocker
Date: 6 Jul 2003 20:04:40
Message: <3f08b918@news.povray.org>
I wish there would be a way to do the same effect in povray. With media or
something.....
Date: 6 Jul 2003 20:27:23
Message: <3f08be6b@news.povray.org>
Well, what I've come up with is to render the image
with pure specular-highlights, rest black. This is loaded
as an image-map, blurred via successive function/image-map,
and finally treated through another function which will
create white regions as white, and black as transparent.
I was planning on trying to achieve the same effect with
colored highlights, but haven't had the time so far. You
might want to have a look at it anyways.
You'll find it in my Downloads-Section, named Glare-Macros
(pretty far down). The URL is in my sig. There's also an
example animation to view.
Tim
Tim Nikias v2.0
> something.....
Version: 6.0.495 / Virus Database: 294 - Release Date: 30.06.2003
Date: 8 Jul 2003 14:16:28
Message: <3f0b0a7c@news.povray.org>
"Tim Nikias v2.0" <tim### [at] gmxde> wrote in message
news:3f08be6b@news.povray.org...
| Well, what I've come up with is to...
Actually, what you are doing is far more sophisticated than the sky
effect in the pictures. Judging by the description given here, the sky
effect is only capable of brightening or darkening a pixel's original
color. The sky effect would be simple to duplicate in POV, but would be
unable to give the effect of bright light shining through a window, or
of a flashlight beam pointed a the viewer. Your process, Tim, appears as
if it could accomplish these things once you get the color recognizing
bit coded in. What neither could accomplish, however, is something like
a bright light shining through a chain link fence, because both use
blurring when proximity is actually what you are attempting to simulate.
 -Shay
