POV-Ray : Newsgroups : povray.binaries.images : Isosurface approximation MkIII Server Time
29 Mar 2026 17:22:46 EDT (-0400)
  Isosurface approximation MkIII (Message 1 to 5 of 5)
Subject: Isosurface approximation MkIII
Date: 1 Jul 2003 02:12:53
Message: <3f012665@news.povray.org>
ok I finally finished this and it's relativly fast as well. there are
a couple of modifications however but they can wait, in the mean time it can
be downloaded from
http://www.geocities.com/qsquared_1999/pubfiles/pubfiles.html if anyone is
interested.
approximation.jpg took 7s to render
real.jpg took 50s to render
f = function(x,y,z) {
    f_sphere(x,y,z,1)+f_wrinkles(x,y,z)
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg"
,r,1))-97;disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4
pigment{rgb 10}}_(r+1)#end#end _(1)//KL
Download 'approximation.jpg' (15 KB) Download 'real.jpg' (15 KB)
Preview of image 'approximation.jpg'
Preview of image 'real.jpg'
Subject: Re: Isosurface approximation MkIII
Date: 1 Jul 2003 07:42:38
Message: <3F0173AD.5070405@spam.fr>
I like the approximation better.   :-p
I work a lot with isosurfaces these times, so you can guess if I'm
interested.
JC
> be downloaded from
> interested.
> Kevin
Date: 6 Jul 2003 15:07:09
Message: <3f08735d$1@news.povray.org>
"Kevin Loney" <kev### [at] ekoikcom> wrote in message news:3f012665@news.povray.org...
> be downloaded from
> interested.
This is great! Thank you for your work.
I've immediately tried it, but the parsing of the <80,80,80> example took my old
computer so long that I decided to see if it could be made faster.
I was surprised that 'if statements' were slowing down the parsing considerable so
I've changed them if possible (gain of about 10%).
I've changed the calls to 'math.inc' for the smooth triangles into functions. That
gave
a considerable improvement in time again (now 22%).
The interpolation macro is changed into direct code (slight improvement: now 27%).
The major change is in the calculation of the vertex function values of the grid
cells.
In the original file all vertices are calculated for every grid cell, but that
means that
the values for inside grid cells are calculated eight times for the same
X,Y,Z-point.
I've changed this in two YZplane arrays and transfer the data from the right
YZplane
to the left YZplane if 'X' is increased with 'xstep'. Although the overhead is
greater,
there is a light improvement in speed, but I think that it will be considerable if
the
isofunctions become complicated.
I've made a switch  named OLD to compare both include files in the '.pov' file, so
you can compare the results. For me the total improvement was 37.5%.
Jaap Frank
Date: 6 Jul 2003 15:09:52
Message: <3f087400$1@news.povray.org>
Sorry, forgot to mention that I posted the new files in
povray.binaries.scene-files.
Jaap Frank
Date: 7 Jul 2003 09:25:19
Message: <3f0974bf$1@news.povray.org>
The results look good, but these types of algorithms use *so* many
vertices that you should continue your work by coding in some simple
mesh reduction steps into your macro.
 -Shay
