POV-Ray : Newsgroups : povray.binaries.images : pecil sharpeners [WIP] v2.0 (142 KB) Server Time
1 Jan 2026 13:55:06 EST (-0500)
  pecil sharpeners [WIP] v2.0 (142 KB) (Message 1 to 6 of 6)
Subject: pecil sharpeners [WIP] v2.0 (142 KB)
Date: 20 Jun 2003 03:38:20
Message: <3ef2b9ec@news.povray.org>
hi there,
some improvements have been made:
- two area lights instead of my pathetic attemps with 30 individual
light_source's
- sheet of paper has been added
- texture of wood has been rotated by 5 degrees
things that need work:
- the floor tiles are to small
- the white box needs a "function"
- render it with focal blur
- turbulence in the wood (need to check the manual for that :-))
comments are appreciated as always.
render time: 29 minutes on a 500 mhz CPU
JWV
Download '2_1.jpg' (143 KB)
Preview of image '2_1.jpg'
Subject: Re: pecil sharpeners [WIP] v2.0 (142 KB)
Date: 20 Jun 2003 09:45:01
Message: <web.3ef30eae3cd4a5acaf6300e0@news.povray.org>
Can you add some thickness to the paper? I think it needs at least a teeny
bit of shadow to suggest that it is has some relationship with the floor.
Can't put my finger on it exactly.
-Peter
JWV wrote:
>hi there,
>light_source's
>JWV
Date: 20 Jun 2003 11:16:54
Message: <3ef32566@news.povray.org>
i see what you mean, but maybe the effect will be better if i wrinkle the
paper a bit, but this will mean i need to make an HF, or mesh. Both of these
techniques are very unfamilliar to me, so that will take a while.
JWV
"pmccombs" <pmc### [at] hotmailcom> wrote in message
news:web.3ef30eae3cd4a5acaf6300e0@news.povray.org...
> -Peter
> JWV wrote:
> >hi there,
> >light_source's
> >JWV
Date: 20 Jun 2003 11:36:40
Message: <3ef32a08@news.povray.org>
that already looks a lot better :)
JWV <jwv|at|planet.nl> wrote in message news:3ef2b9ec@news.povray.org...
> hi there,
> light_source's
> JWV
Date: 20 Jun 2003 13:09:38
Message: <3ef33fd2$1@news.povray.org>
"Ross Litscher" <lit### [at] osuedu> wrote in message
news:3ef32a08@news.povray.org...
> > hi there,
> > light_source's
> > JWV
Date: 20 Jun 2003 17:35:01
Message: <web.3ef37ce53cd4a5a61b99e900@news.povray.org>
It's looking good! :)
FWIW, I would rotate the wood pattern a few degrees around the axis of the
sharpener (the same axis a pencil would align with) to fix the sides up
with
a proper grain, and add a little (or little more...) turbulence... and maybe
a little shine, since they'd probably be polyurethaned or otherwise
finished.
But maybe that's just me...
--Chris
