POV-Ray : Newsgroups : povray.binaries.images : Grassy Julia Fractal Server Time
21 Jul 2026 19:39:01 EDT (-0400)
  Grassy Julia Fractal (Message 13 to 22 of 22)
Subject: Re: Grassy Julia Fractal
Date: 14 Jun 2003 22:25:19
Message: <3eebd90f@news.povray.org>
Tek <tek### [at] evilsuperbraincom> wrote in message
news:3eebc98c$1@news.povray.org...
> "Ross Litscher" <lit### [at] osuedu> wrote in message
> news:3eebc63e$1@news.povray.org...
> > atleast the grass is long.. i'd hate to think someone has to mow this
yard
> Woah, that would be difficult... The only way you could mow that would be
to
> employ a sheep to graze on the grass, actually a mountain goat would be
> better...
you now know what you must do. start dropping those goats out of the sky! =)
Date: 15 Jun 2003 04:19:21
Message: <3eec2c09$1@news.povray.org>
Thanks!
Hm, so that dividing along the length with the texturing
trick... Do you use just two triangles per blade, or
more? Thats what I couldn't figure out from yer description.
How fast is it? And yet to be answered: how many blades
are in the currect scene?
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Darn, my news reader just crashed as I was writing a reply to this! I'll
try and
> remember what I said...
> Basically it's just a mesh. Each blade is triangular, and is divided in
two
> along it's length so I can texture it. The texture is uv mapped so that
the
> blade is opaque at the center of it's base, and fades to transparent at
the
> edges. This gives a nice soft appearance without the need for hundreds of
focal
> blur samples :) The blades also vary slightly in colour.
> Each blade is placed using the trace() function, by firing a ray
vertically down
> onto the object. The blade is oriented to point in the direction of the
surface
> normal, and then the top point is displaced by a vturbulence() function
and a
> small random displacement.
> Here's a couple of bits of source code to help explain that:
> //trace a position onto the object
> #macro m_Place(vP)
>  (trace( oHill, vP+y*5, -y + .3*(<rand(rs),rand(rs),rand(rs)>-.5),
vPlaceNorm )
> + vP.y*y)
> #end
> #declare vPos = 1.3*<rand(rs)*2-1,0,rand(rs)*2-1>;
> #declare vPos = m_Place(vPos);
> #declare vTop = vPos + vPlaceNorm*.0025;
> #declare vTop = vTop + (vturbulence(2, .5, 6, vPos*20)*.0004 +
> (<rand(rs),rand(rs),rand(rs)>-.5)*.0004)*<1,.3,1>;
> I can post the full source if you like, but I'll probably carry on working
on
> this image so I'd rather wait until it's "finished".
> Tek
> http://www.evilsuperbrain.com
> "Tim Nikias v2.0" <tim### [at] gmxde> wrote in message
> news:3eebbd41$1@news.povray.org...
> > Would you care to explain a little more in detail how you've
> > gone about creating the grass? Placing, object's orientation,
> > how many are there, texturing? It looks really great.
> > Tim Nikias v2.0
> > Homepage: http://www.digitaltwilight.de/no_lights
> > > > Fantastic! Add some flowers, bees or butterflys,
> > > > position the camera a little different to make
> > > > the fractal more visible, and you've made yourself
> > > > a picture worthy of Zazzle!
> > > Good ideas, that's the kind of thing this scene needs. Though at the
> > moment I'm
> > > playing with the lighting instead...
> > > I have to admit I didn't think it was that good, but people really
seem to
> > have
> > > picked up on the atmosphere of it so I think I'll develop it further
> > > Tek
Date: 15 Jun 2003 06:37:52
Message: <20030615123750.019b2a8d.jaimevives@ignorancia.org>
On Sat, 14 Jun 2003 22:10:51 +0100
> I like it, it has a nice unreal feeling. What do you think?
  I feel the need to touch it! But it looks more like velvet than grass,
to me (I will like to see it with some nice brown or blue tone).
  Perhaps it would be nice to have the lower part into the water,
letting some foreground space to see the reflections. Anyhow, really
amazing...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 15 Jun 2003 09:28:03
Message: <3eec7463$1@news.povray.org>
news:3eec2c09$1@news.povray.org...
Yup 2 triangles per blade. The texture fades from opaque to transparent on the u
axis, and from yellow to green along the v axis. Each blade is mapped with the
same v value on all corners, to pick the colour of the blade, and with the u
value setting how opaque it is.
> How fast is it?
About 2 hours for this image at 1600x1200
250,000!
The bliss image rendered a lot quicker even though there were more blades,
because I created a mesh of 100,000 blades then duplicated it 40 times with
small random displacements. I couldn't do this on this scene because the object
is so complex that it became obvious some of the blades weren't touching it, so
this actually has 1 mesh with 500,000 triangles in it!
Tek
Date: 15 Jun 2003 09:31:26
Message: <3eec752e$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:200### [at] ignoranciaorg...
Yeah, I was thinking it looked soft, like fur. I may have to render an
alternative version that's covered all over with brown fur :)
> amazing...
Good suggestion (and very easy to do!) I'll give it a go.
Tek
Date: 15 Jun 2003 09:34:19
Message: <3eec75db$1@news.povray.org>
Correction: more like 7 hours! I read the wrong render time.
Tek
news:3eec7463$1@news.povray.org...
u
> > How fast is it?
> 250,000!
object
so
> Tek
Date: 15 Jun 2003 14:56:14
Message: <3eecc14e@news.povray.org>
Very nice !  I like it very much too.
Fabien.
Date: 15 Jun 2003 16:02:28
Message: <3eecd0d4@news.povray.org>
Tek wrote:
> I decided to apply the grass from my "bliss" image to a more interesting object,
> so I made this rather surreal scene.
> The grass looks far better than I thought it would do. Each blade of grass is
> straight, but there's realy nice curves in the overall effect because they lean
> with the shape of the fractal, and also there's a turbulence pattern displacing
> the tops of the blades so you get the feeling the wind is blowing across them.
> Also there's a halo effect round the edge, which has happened completely by
> accident! :)
Nice start.. I have some suggestions.
First, tweak your grass-placing code so you don't have grass growing
straight out sideways. ^^;;
Someone posted a picture a while back that used multilayered grass: a
smaller, browner layer and a larger green layer. It worked really well.
It's possible that this image would be better off with just the bright
green - it adds to the surrealistic look - but you might want to play
with that and see what happens.
A few flowers or something would look good.. doesn't have to be a lot,
just enough to add a little variety.
I really like the idea of the chair and umbrella that someone mentioned,
but I'd leave out the sign and the rowboat; let the furniture speak for
itself, I think, and if a boat's there then there should also be a
person there, since the boat didn't row itself, and now your scene's
just getting messy.. see?
I look forward to more development. This would make great wallpaper. :D
-Xplo
Date: 16 Jun 2003 03:42:07
Message: <3EED74CE.9040409@spam.fr>
Waooww, looks real nice.
The grass looks a bit furry, but that adds softness to it.
I would lower the spiky hairy feeling on the edges by "verticalizing"
the normals when they get too horizontal. I also like the Idea of Jaime
to have a reflection on the water.
Anyhow, it's great ! I'd like to be able to do such images.
JC
> accident! :)
> Tek
Date: 16 Jun 2003 04:56:49
Message: <u21revgs9o207rjqi6fsik2518b3q2cu84@4ax.com>
On Sat, 14 Jun 2003 22:10:51 +0100, "Tek" <tek### [at] evilsuperbraincom>
I love it! I'm fond of surreal images and this is a nice one.
I have one suggestion for a variation of this image. On the largest
flat and level area of the grass, (approximately near the center of
the image), there should be a person riding a red lawn mower from the
right side of the image to the left side. There would be a small swath
of newly mown grass in their wake, with the expectation that they
would proceed up the "hill" on the left of the image, circle around
the peak, and come back again to the foreground.
It should look quite interesting and puzzling.
later,
Glen Berry
