POV-Ray : Newsgroups : povray.binaries.images : meshes and df3s Server Time
23 Aug 2025 19:22:32 EDT (-0400)
  meshes and df3s (Message 1 to 10 of 23)
Subject: meshes and df3s
Date: 23 May 2003 13:13:03
Message: <3ece569f@news.povray.org>
Hi All
No pretence to artistic merit here - more a progress report.
Inspired by Gilles makecloud macros and the dicovery that I could get
tga2df3 to work on XP I tried making a df3 from a Poser mesh. After some
fumbling about and a helpful suggestion from Gilles, I succeeded :-)
Here is the result Vicky, takes to the cat walk, converted to df3s and
rendered in a vile orange media with just a hint of turbulence.
If any one is interested I'll post the code when I've tidied it, it really
is very simple.
Mick
Download 'makeshape_test.jpg' (34 KB)
Preview of image 'makeshape_test.jpg'
Subject: RE: meshes and df3s
Date: 23 May 2003 13:27:31
Message: <3ece5a03$1@news.povray.org>
noticias 3ece569f@news.povray.org...
> is very simple.
I'm very interest on the code and in the way to make a df3 file
form an .obj file (I have a model waiting for this, and it's getting
nervous ;-)
Bye.
Txemi Jendrix
http://www.txemijendrix.com
Subject: Re: meshes and df3s
Date: 23 May 2003 13:58:09
Message: <3ece6131@news.povray.org>
Code in p.b.s-f
Mick
Date: 23 May 2003 14:00:22
Message: <3ECE61B5.487842B4@gmx.de>
Nice, but i suppose you know you don't need to generate a df3 to render a
mesh filled with media...
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 23 May 2003 14:21:47
Message: <3ece66bb@news.povray.org>
Yes but you can't apply turbulence to the mesh! You can attack the df3
rendered in media in a number of ways yet to be tried. I suppose you could
use the mesh in an object pattern but I havn't tried that yet!
Mick
Date: 23 May 2003 16:23:34
Message: <3ece8346@news.povray.org>
3ECE61B5.487842B4@gmx.de...
In the case of Poser meshes (and many other meshes) it's in fact the only
way to fill them properly because they often have internal structures that
are likely to interact badly with media (see some older subsurface
scattering tests). Poser heads are very big offenders in that respect as
they have teeth, nostrils, tongues, eyeballs etc.
I once tried to remove the annoying organs by hand in a modeller but it's
not the most fun work in the world... And of course, as Mick says,
turbulence is a real creative bonus.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 23 May 2003 16:27:51
Message: <3ECE8447.C722F690@gmx.de>
But don't the same problems also cause errors when generating the df3?
Date: 23 May 2003 16:40:24
Message: <3ece8738$1@news.povray.org>
> a mesh filled with media...
Is there a speed difference? (renderwise)
Date: 23 May 2003 21:59:18
Message: <3eced1f6$1@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3ECE8447.C722F690@gmx.de...
only
that
Hmmmm, not noticable with the tongue & teeth but it looks like the breast
implants affected it.  Something about the properties of silicone I
imagine... ;)
RG
Date: 24 May 2003 10:39:48
Message: <3ecf8434@news.povray.org>
No, because when the df3 is generated, either by slicing or by using object
pattern, everything within the mesh appears in the same colour so the
internal structures are hidden.
Another interesting property of the method, btw, is that by using focal blur
during the generation it is possible to make the edges even more fuzzy.
G.
- Posters
