POV-Ray : Newsgroups : povray.binaries.images : Problem with 'seams' in merge. Server Time
14 Jul 2026 04:17:20 EDT (-0400)
  Problem with 'seams' in merge. (Message 11 to 16 of 16)
Subject: Re: Problem with 'seams' in merge.
Date: 20 May 2003 19:03:50
Message: <3ecab456@news.povray.org>
Thank you for your many suggestions!  I tried the bigger cone as you
suggested and it worked perfectly.
Download 'thingy2.jpg' (332 KB)
Preview of image 'thingy2.jpg'
Date: 21 May 2003 15:21:10
Message: <3ECBD239.9020103@ibras.dk>
Ken wrote:
> Tor Olav Kristensen wrote:
>>#macro MakeThingy...
> Nice name :)
Didn't the Brits put a tax on that? :) See
http://www.ibras.dk/montypython/episode15.htm#4
/Ib
Date: 21 May 2003 16:15:06
Message: <3ecbde4a$1@news.povray.org>
Better than a Micro MakeThingy I suppose.  ;-)
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3ECAAD86.BF1C2643@pacbell.net...
> Nice name :)
> Ken Tyler
Date: 21 May 2003 21:43:37
Message: <3ECC2B71.F727BB5B@pacbell.net>
A fine point.
Ken Tyler
Date: 22 May 2003 03:26:10
Message: <3ecc7b92$1@news.povray.org>
On Mon, 19 May 2003 21:23:35 -0400, Sun Tzu wrote:
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <HTML><HEAD>
	And other strange tags. ;)
	I read some of the responses and I don't know if this will help but most
graphics programs, Photoshop, gimp have a "make seamless" option which
will correct the general problem with seams on a sphere. But not knowing
the image you are using I can't save if that will preserve the image you
are trying to use. Another thing is you must start with a mercator
projection image else the "poles" will be "scrunched" into points at the
poles. There is no good solution for that problem.
Date: 22 May 2003 22:04:33
Message: <Xns93842A5E75415torolavkhotmailcom@204.213.191.226>
simian <sim### [at] localhostlocaldomain> wrote in
news:3ecc7b92$1@news.povray.org:
>      but most
> knowing the image you are using I can't save if that will preserve the
> image you are trying to use. Another thing is you must start with a
> mercator projection image else the "poles" will be "scrunched" into
> points at the poles. There is no good solution for that problem.
You are probably thinking of problems with mapping of
rectangular images onto spheres, while the problem with
his sphere was that it had tiny gaps (caused by roundoff
errors) between the CSG parts that forms his shape.
Tor Olav
