POV-Ray : Newsgroups : povray.binaries.images : WIP: Arietta 2 (290 kb) Server Time
15 Nov 2024 20:20:15 EST (-0500)
  WIP: Arietta 2 (290 kb) (Message 1 to 7 of 7)
Subject: WIP: Arietta 2 (290 kb)
Date: 17 May 2003 10:01:44
Message: <3ec640c8@news.povray.org>
I resumed work on the image I submitted to the Sep - Oct
2002 IRTC. After adding radiosity and photons, the result
was much too white so I changed the material of the terrain
from white stone to light wood randomly mixed with dark wood.
The present terrain consists of just two types of elements:
about 15,600 light wood cylinders with dark silver knobs and
780 dark wood cylinders with a thin golden torus at the top
and a small glass sphere hanging slightly above the top end.
All the colour differences are caused by the illumination,
either directly by the colour of the surrounding lights or
else by reflection and refraction. The soft reflections below
the harpsichord are caused by multiple reflections between two
plates of glass. The flute is illuminated in varying degrees
by the light refracted by the sphere above it.
The eye is a composite of a small segment of a photograph and
a glass sphere on the iris to reflect the lights in a more
natural way. There is a bozo height field glass plate in front
of the eye so I can render the image at 7620x5080 without fear
of all too obvious pixelation (the original is about 400 pixels
wide only).
   Veijo
Download 'arietta_2.jpg' (291 KB)
Preview of image 'arietta_2.jpg'
Subject: Re: WIP: Arietta 2 (290 kb)
Date: 17 May 2003 11:11:13
Message: <3ec65111$1@news.povray.org>
Veijo,
May or may not be the reaction you are after, but I presonally find this image
very unsettling. Even after thinking about it a bit I am not sure why. Good
work! :-) The keys on the keyboard appear to have merged in the posted image,
but I expect the keyboard looks OK at the larger resolution?
Regards, Bill
Subject: Re: Arietta 2 (290 kb)
Date: 17 May 2003 11:49:25
Message: <3ec65a05@news.povray.org>
Veijo:
Awesome.  Very nice combination of realism and the fantastic.
I am inspired to try something like this on my own.
Aaron
"Veijo Vilva" <vei### [at] animalhelsinkifi> wrote in message
news:3ec640c8@news.povray.org...
> Hi,
> wide only).
>    Veijo
Date: 17 May 2003 14:09:24
Message: <3ec67ad4@news.povray.org>
William F. Pokorny wrote:
> Veijo,
> image very unsettling. Even after thinking about it a bit I am not sure
> why. Good work! :-)
Thanks.
It is supposed to be something _different_. I've rendered the original
version at a resolution of 7620x5080 and had a photographic print made
at 254dpi (i.e. 30"x20", that's 76.2cm x 50.8 cm). It sure attracts
attention. This version I'm now rendering at a resolution of 6000x4000
only as I must have a print made before June 15th, and it takes about
three weeks to render at that resolution with a 2.4GHz P4.
> the posted image, but I expect the keyboard looks OK at the larger
> resolution?
Yeah, it's impossible to have all the details visible at the screen
resolution. However, I design everything so that I can go very near
the models without things starting to fall apart. I've attached a
close-up of the keyboard, and you can find more pics at my gallery:
    http://www.animal.helsinki.fi/people/vilva/gallery/
    Veijo
Download 'keyb.jpg' (35 KB)
Preview of image 'keyb.jpg'
Date: 17 May 2003 17:15:59
Message: <3ec6a68f$1@news.povray.org>
Very nice. Can you describe how you did the eye? No post processing in
Photoshop?? {:-)
Best.
D.
> Hi,
> wide only).
>    Veijo
Date: 17 May 2003 18:40:43
Message: <3ec6ba6b$1@news.povray.org>
Very artistic, clever and good modelling too! I really like this.
Date: 18 May 2003 01:42:50
Message: <3ec71d5a@news.povray.org>
> Photoshop?? {:-)
No post-processing what so ever, I never do.
Here is the relevant part of the code, with some comments.
I hope this helps.
   Veijo
box { <0,0,0>, <1,1,0.01>
   pigment { image_map { tga "eye.tga" } } // the eye photo,
      // which is a straight crop from a larger photo
   translate <-0.5,-0.5,0> scale <1.5,1,1>
      // translate to the origin, restore format to 3:2
   rotate 18.5*x translate <0,-0.09,1> } // rotate to correct
  // for the perspective as the camera isn't quite horizontal
sphere { <-0.06,-0.1,1.02> 0.03 texture { T_Gold_3C } }
   // NB. this sphere is there just for a visual effect
sphere { <-0.07,-0.145,1.18> 0.295
   // for the iris reflections
   // position and dimensions empirical
   texture { T_Glass3 } interior { I_Glass } }
// actually, these two spheres ought to be unioned
// with the photo before the corrective rotation
union {             // this does the job
   height_field {
     tga "hf2b.tga"  // a bozo height field
     smooth scale <2, 0.015, 2> }
   box { <0,-0.101,0>, <20,-0.098,15> }
    // something like this seems to be required to make the HF work
   rotate -90*x translate <-1,-1,0.7>
   pigment { rgbt <1,1,1,1> } interior { ior 1.05 }
    // the ior value is empirical, modify ad lib
