POV-Ray : Newsgroups : povray.binaries.images : Metallic paint - HDR renders Server Time
15 Apr 2026 08:38:33 EDT (-0400)
  Metallic paint - HDR renders (Message 11 to 18 of 18)
Subject: Re: Metallic paint - HDR renders
Date: 16 May 2003 17:13:05
Message: <3ec55461@news.povray.org>
Here's a much improved glitter effect, you can see that it only occurs near the
reflections of bright objects, and is the colour of those objects.
For anyone who's curious, I've acheived this effect using a dome of 50
lightsources sampled from teh HDR image, with a higher probability of
lightsources occuring in the brightest areas of the dome (otherwise I need about
300 to get a similar result).
Tek
http://www.evilsuperbrain.com
news:3ec5217c$1@news.povray.org...
> "JWV" <jwv|at|planet.nl> wrote in message news:3ec494d3@news.povray.org...
> > I think you should leave out the glitter on the black part of the object.
> I agree, that occured because I created the glitter effect with only one light
> source, but now it's surrounded by a dome of lights the glitter appears all
over
> the surface. It should be possible to refine it without making it look less
> glittery.
> Tek
Download 'metal hdr glitter.jpg' (58 KB)
Preview of image 'metal hdr glitter.jpg'
Date: 16 May 2003 17:31:20
Message: <3ec558a8@news.povray.org>
Hold on, did you mean the black part or the dark part? I thought you meant the
dark part, i.e. the bit in shadow, but I just realised maybe you mean the bit
that's painted black! Doh! Sorry I should pay more attention :)
Tek
over
> glittery.
> Tek
Date: 16 May 2003 20:50:34
Message: <3ec5875a@news.povray.org>
Wow......
BTW, What is HDR?
Gary
news:3ec40598@news.povray.org...
> I discovered HDR looks a *lot* better with assumed_gamma 1, so I've
rendered a
> few more versions. With this gamma setting there's not so much saturation
on the
> bright points, so we can have light and dark things in the same scene more
> realistically.
> Tek
Date: 16 May 2003 21:50:14
Message: <3ec59556$1@news.povray.org>
"Ace" <ble### [at] icefognet> wrote in message news:3ec5875a@news.povray.org...
> BTW, What is HDR?
High Dynamic Range, it's a way of representing true light values within a
picture. There's more info here: http://www.debevec.org/Research/HDR/
Tek
Date: 17 May 2003 04:00:35
Message: <3ec5ec23@news.povray.org>
i meant the part wich is painted black :-).
news:3ec558a8@news.povray.org...
the
bit
> Tek
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
object.
light
all
> over
less
> > glittery.
> > Tek
Date: 17 May 2003 07:38:08
Message: <3ec61f20$1@news.povray.org>
"JWV" <jwv|at|planet.nl> wrote in message news:3ec5ec23@news.povray.org...
Doh! Well I agree that metallic black looks wierd, but I did it because it was
requested. Anyway your suggestion made me realise that the glitter didn't seem
to be related to the lighting in the right way, and that's prompted me to make
it even better so thank you anyway :)
Tek
Date: 17 May 2003 14:05:59
Message: <3ec67a07$1@news.povray.org>
thank you!
i will have a look at this
keep up the good work
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:3ec5538e$1@news.povray.org...
> The backgrounds are HDR (high dynamic range) photos from Paul Debevec's
site:
> http://www.debevec.org/Probes/
> They're rendered using MLpov, a modified version of POV3.5 which has
support for
> HDR: http://pov.monde.free.fr/mael/mlpov081eng.html
> I started using HDR just the other day, but it's taken me only a couple of
> evenings to get these kinds of results.
> Tek
> "Lenx" <len### [at] pandorabe> wrote in message
news:3ec54f01$1@news.povray.org...
> > very great work tek! i'm blown away!
> > maybe this is a little off topic, but how did you make the environment?
they
> > look realy nice and add a pic part to the paint.
> > sorry if this is mentioned somewhere else, but i have not enough time to
> > read everything closely.
> > regards
> > lenx
> > news:3ec2d3a3@news.povray.org...
> > > For anyone who hasn't been following the other thread: I can't
illuminate
> > my
> > > metallic paint using only radiosity, as it relies on specular
highlights,
> > which
> > > meant I couldn't light it using HDR...
> > > ...but now I've found a way round it: Here the object is lit by a set
of
> > light
> > > sources distributed round a sphere, with their colours sampled from
the
> > HDR
> > > image. It's very effective and it means I can just change the HDR and
it
> > looks
> > > right. I've not used radiosity, but I guess to combine this with
radiosity
> > you'd
> > > need to turn off the HDR sky sphere and save the radiosity, then turn
it
> > back on
> > > for the final render, otherwise the light sources will combine with
> > radiosity
> > > from the sky sphere and cause twice the illumination in the scene.
> > > Anyway, the pictures show the paint in a variety of HDR environments,
and
> > the
> > > beach and campus pictures are using a much more metallic type of paint
> > (90%
> > > metallic, compared to 60% in the other pictures).
> > > The metallic paint is the same code used for the other picture, which
is
> > on
> > > p.b.s-f. I can provide the source code for the light dome trick if
anyone
> > wants
> > > it, but it's pretty straighforwards and my version is a little messy.
> > > You like? :)
> > > Tek
Date: 18 May 2003 21:15:12
Message: <3ec83020@news.povray.org>
Ahhhh... Thanks!
Gary
news:3ec59556$1@news.povray.org...
> > BTW, What is HDR?
> Tek
