POV-Ray : Newsgroups : povray.binaries.images : Noob Help Request (WIP Wine V0.02) Server Time
21 Apr 2026 09:01:31 EDT (-0400)
  Noob Help Request (WIP Wine V0.02) (Message 1 to 10 of 10)
Subject: Noob Help Request (WIP Wine V0.02)
Date: 29 Apr 2003 12:58:42
Message: <3eaeaf42@news.povray.org>
This is my first post on these news groups so I'm unsure of the
prevailing etiquette here, and how strictly it is observed.   I
apologize in advance if I have violated the rules by posting a text
request for help, image, and some source text in the same message/group.
I've been trying to make my first scene using primarily the POV SDL.
The initial scene and some of the objects were modeled in Moray.
Rendering has been done using MLPOV V0.81 (for HDR image support).
What has me perplexed is the exact effect and relation between the
<rgbf> color in the 'pigment' section and fade_color and such in the
'interior' section.  Here are the material definitions for the wine and
the glass:
#declare winered =
   material  // winered
      texture
         pigment
            color rgbf <0.3, 0.0, 0.0, 1.0>
         finish
            ambient 0.1
            diffuse 0.1
            phong 1.0
            phong_size 100.0
            specular 0.8
            roughness 0.0003
            reflection 0.1
      interior
         ior 1.45
         fade_distance 100.0
         fade_power 1.0
         fade_color <1.0, 0.0, 0.0>
#declare Crystal_1_1_1 =
   material  // Crystal_1_1_1
      texture
         pigment
            color rgbf <.98, .98, .98, .9>
         finish
            ambient 0.0
            diffuse 0.1
            phong 1.0
            phong_size 100.0
            specular 0.8
            roughness 0.0003
            reflection 0.1
      interior
         ior 1.45
         fade_distance 10.0
         fade_power 1.0
         fade_color <0.98, 0.98, 0.98>
I think I've read most of the relevant documentation, and I'm still not
100% sure if what I'm trying to do can be done with POVRay or not.  I'm
trying to get a colored shadow cast by the wine in the glass.  So far I
haven't been able to get anything but a gray shadow.
I've also tried photons to get a colored caustic but that hasn't worked
out either.  I think my problem with the photons is that I only want a
caustic from the wine and not the glass, but the wine is inside the
glass, and I suspect that the glass is blocking the photons.  I put a
photon block in the glass object (also added a global photon block and a
light source photon block of course) with a 'pass_through' in it, but it
still didn't look like it was working correctly.
I'd appreciate any advice or suggestions anyone might have, either
related to the problem mentioned above or just general comments and
ideas.  To give a better idea of what the scene looks like right now
here is an image from render I did with radiosity, but no photons.
Thanks.
Download 'iso-8859-1' (7 KB)
Subject: Re: Noob Help Request (WIP Wine V0.02)
Date: 29 Apr 2003 14:15:05
Message: <web.3eaec0cb5032ae199a89ca810@news.povray.org>
Sun Tzu wrote:
>I'm trying to get a colored
>shadow cast by the wine in the glass.  So far I haven't been able to get anything but
>a gray shadow.
>I'd appreciate any advice or suggestions anyone might have, either related to the
>problem mentioned above or just general comments and ideas.  To give a better idea of
>Thanks.
This is just a quick reply, I haven't tested anything yet, But have you
tried just using faked caustics?
interior{
    caustics (some number between zero and one)
this should create a  colored area in the shadow of your wine.  Lower
non-zero values give broader hotspots, while closer to one gives sharp
highlights.
Date: 29 Apr 2003 18:12:28
Message: <3eaef8cc@news.povray.org>
you
> interior{
> highlights.
Thank you for the response.  I tried what you suggested along with
lightening the color of the wine from <0.3,0,0> to <0.4,0,0>.  It seems
to work, but the effect is a little more subtle than I had hoped.
Perhaps what I expect just isn't realistic.  hehe.
Download 'iso-8859-1' (2 KB)
Date: 30 Apr 2003 04:03:15
Message: <3EAF8338.2030104@informatik.uni-freiburg.de>
One comment, but not to the caustics:
>          pigment
You put the filtering effect into the texture. A thin drop of wine will
then have the same filtering effect as a deep pool of wine. My experience
with red wine (which is little enough, as I always prefered white wine)
is different. Therefore I would put the filtering effect into the material's
interior, like this:
   pigment {transmit 1}
   interior {media{
     absorption <0,1,1>*some_factor
I am no expert on making good materials, so treat my advise with caution.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 30 Apr 2003 18:58:39
Message: <slrnbb0l1p.vnq.steve@zeropps.org.uk>
It's out there!
                                             or http://start.at/zero-pps
 11:53pm  up 53 days, 20:19,  1 user,  load average: 1.20, 1.16, 1.09
Date: 1 May 2003 02:41:39
Message: <3eb0c1a3$1@news.povray.org>
This is the best glass / bottle scene I've ever seen in POV. The reason is,
it's still rare that one sees specular reflection from images (hdri or not)
rather than infinite small pointlights.
Hugo
Date: 1 May 2003 09:03:36
Message: <3eb11b28$1@news.povray.org>
Thanks.  :-)
I must say when I first heard about using HDRI or any image for that matter,
I thought it was kind of 'cheating', but it sure does make for pretty
reflections, and it really seems like a waste to model all kinds of stuff
just for it to show up in a miniscule distorted reflection.  hehe.
"Hugo Asm" <hua### [at] post3teledk> wrote in message
news:3eb0c1a3$1@news.povray.org...
is,
not)
> Regards,
> Hugo
Date: 1 May 2003 09:08:51
Message: <3eb11c63$1@news.povray.org>
Thank you for the suggestion.  I will try using media, although I must
confess I'm rather confused about the difference between the media
absorption parameters as opposed to the fade_power, fade_distance,
fade_color specifications.  Isn't the fade_... stuff supposed to do the same
thing as the media absorption stuff?   If not, what is the difference and
when should I use one instead of the other?
"Mark Weyer" <wey### [at] informatikuni-freiburgde> wrote in message
news:3EA### [at] informatikuni-freiburgde...
> >          pigment
material's
>    interior {media{
Date: 1 May 2003 21:47:58
Message: <3eb1ce4e@news.povray.org>
Sun Tzu <sun### [at] nospamhotmailcom> wrote in message
news:3eb11c63$1@news.povray.org...
same
Okay, I'll admit that I didn't know either just off the top of my head.  So
I went and made this, after re-reading the documentation of course.
Okay, furthest to the left is media absorption,  The media absorbs green
blue and some red light (<.5,1,1>) and so the shadow is white minus half the
red, and all the rest (<.5,0,0>).
in the middle is fade.  In the fade there is no media, the fade_distance is
.5 (the radius of the sphere is 1), the fade_power is 1.5 (docs said use a
number between 1 and 2 so...), fade_color is <1,0,0> so all red (I tried
<0,1,1> but this blocked all red light...).
The sphere on the right is just a red sphere with filter and transmit of .75
and caustics on.
So!  Absorption absorbs light, and fade blocks light.  I think you could
achive similar effects using either... except that absorbing media can be
applied at with a density map, so where media is thickest it will absob the
most light.
Download 'test.jpg' (9 KB)
Preview of image 'test.jpg'
Date: 2 May 2003 16:13:10
Message: <3eb2d156@news.povray.org>
Nice.  Thanks for the image.  I'll take a close look at it, and run some
experiments too.
"Kitsune_e" <kit### [at] hotmailcom> wrote in message
news:3eb1ce4e@news.povray.org...
> same
and
So
the
is
.75
> and caustics on.
the
> most light.
