Try as I might, I *cannot* get this to look metallic... *sighs* Tried
playing with lighting, tried playing with different backgrounds, but I can't
make it look shiny, and I can't make it look reflective!
Any suggestions? (I'm looking for a very highly-polished, very brilliant
look.)
Thanks.
Andrew.
Download 'Spins1.jpg' (202 KB)
Preview of image 'Spins1.jpg'
> look.)
Have you tried any of the chromes or silvers from the standard includes?
Remember that metals need somthing to reflect, to look metallic.
/Ib
I had the same trouble the other day, but eventually got something I liked.
A few tips:
-make sure you've got a light source in a position where it will reflect, and
use a specular or phong highlight
-make it slightly reflective
-use a high brilliance value, I find a brilliance of 2 looks pretty good.
-try using "metallic" reflections and highlights, that sometimes helps (though
sometimes it looks totally wrong).
Tek
http://www.evilsuperbrain.com
"Andrew Coppin" <orp### [at] btinternetcom> wrote in message
news:3ea584f1@news.povray.org...
> look.)
> Thanks.
> Andrew.
> look.)
Try making the pigment darker and maybe the reflections brighter, so that it
relies more on reflected than diffused light.
Maybe try making the highlights sharper, also.
- Slime
[ http://www.slimeland.com/ ]
Nope, not yet. I could do I suppose...
That's the purpose of the daft blue/yellow background. Doesn't seem to help
much though... (Maybe it just needs more contrast, IDK)
Thanks.
Andrew.
liked.
> A few tips:
and
It already has 80% specular highlight. Lighting might well need something
doing to it though...
Already has constant 80% reflection. (Haven't tried variable reflection -
won't make much difference for such tiny objects.)
Brilliance is currently at 3. (Also roughness = 0.005.)
(though
Already switched on. (Of course, all that actually does is make the specular
highlights match the colour of the object; since these are WHITE anyway,
theoritically it won't make any difference.)
Thanks anyway.
Andrew.
it
Yeah, that was my thinking... Tried it with no diffuse at all, but looked
like it was metal painted black or something... (Ooo, but maybe I should
turn off the "metallic" keyword - it's probably trying to give me black
highlights |-)
Yes, I think I agree with you there... Already tried fiddling with roughness
and brilliance, so maybe I need to move the light source around or
something...
Thanks.
Andrew.
Well another idea is put a horizon line in the reflection, make the ground dark
and the sky bright.
If it's in an unrealistic setting it will tend to look unrealistic.
Tek
news:3ea59f29@news.povray.org...
> liked.
> > A few tips:
> and
> (though
> Thanks anyway.
> Andrew.
dark
> and the sky bright.
Hey, that could would... Yes, that's how artists always seem to do it when
they paint by hand... [Sees visions of chrome bikes...]
Scientifically-correct and realistic appearence are two related but SEPERATE
concepts ;-)
Thanks for the hint!
Andrew.
> look.)
The best reflection I got with metals, was with a very highly scaled
black and white checker plane behind the camera.
(Black and white, makes the reflection extremely sharp and nice)
Dedicated to audio/visual and interactive artwork.
Author of The Primary Colors of CSound:
http://www.geocities.com/simonlemieux/PCCS/index.html
