I made a buckyball. I created it using a 6-cornered-polygon and a
5-cornered-polygon, and then started to rotate and translate them around.
The result is good enough for me, but i wonder if there is an easier way to
create a buckyball.
Download 'buccy.jpg' (15 KB)
Preview of image 'buccy.jpg'
You might try looking at:
http://www.ccl.net/cca/data/fullerenes/index.shtml
an archive of fullerene coordinates. The data are in Chem3D format, but
it is trivial to get only the XYZ coordinates. You might even use the
connectivity info within the file to help you define vertices.
Hope this helps.
> create a buckyball.
When I read this my eyes suffer, although for the neolanguage described by
g. orwell in 1984 is correct, a 6-cornered-polygon is a hexagon, and a
5-cornered-polygon, a pentagon
Bruno Gimeno
The mathematics are the language of the nature
news:3e9458d0@news.povray.org...
to
> create a buckyball.
> create a buckyball.
http://www.sevenravens.com/landsailing/bucky.html
http://www.geocities.com/SiliconValley/Lakes/5432/povray/geodesic.html
Ken Tyler
