POV-Ray : Newsgroups : povray.binaries.images : Isosurface approximation Server Time
13 May 2026 11:00:50 EDT (-0400)
  Isosurface approximation (Message 1 to 3 of 3)
Subject: Isosurface approximation
Date: 9 Apr 2003 01:40:54
Message: <3e93b266@news.povray.org>
Just fiddling around with methods to approximate isos using triangle meshs
based on the algorithm described here
http://astronomy.swin.edu.au/~pbourke/modelling/polytetra/, 27s to render 9m
27s to parse using 40 segments along each axis, and 68124 triangles in
total. I'm bundling it all up into an include file, I would image given the
ability to save the mesh so it dosen't have to be reproduced every time
would make it handy for test renders of scenes that are heavy with isos.
Mind you, there is only a noticable speed increase when using complex
functions,
I rendered the iso f(x,y,z) = cos(2*pi*x) + cos(2*pi*y) + cos(2*pi*z) and it
took the same amount of time as the mesh (27s).
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg"
,r,1))-97;disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4
pigment{rgb 10}}_(r+1)#end#end _(1)//KL
Download 'field.jpg' (85 KB)
Preview of image 'field.jpg'
Subject: Re: Isosurface approximation
Date: 9 Apr 2003 03:32:59
Message: <3e93ccab@news.povray.org>
> 9m 27s to parse using 40 segments along each axis, and 68124 triangles in
> the ability to save the mesh so it dosen't have to be reproduced every
> time would make it handy for test renders of scenes that are heavy with
> isos.
Very nice. Keep going. In the past, I often removed isosurfaces from the
scene for test renderings. An easy way to get an approximation is a nice
thing to have.
Date: 9 Apr 2003 07:28:54
Message: <3e9403f6$1@news.povray.org>
9m
the
> functions,
it
If you decrease the amount of triangles, it would render a great deal
faster, with the obvious loss of detail, right? And if you didn't need the
parsing time either.. What about using vertex normals / smooth triangle ?
Maybe that could remove the need for isosurface all together in some
situations?
This is very interesting stuff, keep us posted!
-Peter
