POV-Ray : Newsgroups : povray.binaries.images : Marc Champagne's diamonds again (150 Kb) Server Time
2 Jan 2026 01:50:21 EST (-0500)
  Marc Champagne's diamonds again (150 Kb) (Message 1 to 10 of 15)
Subject: Marc Champagne's diamonds again (150 Kb)
Date: 29 Mar 2003 20:57:33
Message: <3e864f0d@news.povray.org>
Pixels:          480800   Samples:         2783912   Smpls/Pxl: 5.79
Rays:         358123620   Saved:          27967161   Max Level: 100/100
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                         2106014929      1509283441     71.67
CSG Intersection            1459857629       815358445     55.85
Plane                     131387186610     70139956210     53.38
Bounding Object             1470411157      1459857629     99.28
Bounding Box                4941704909      2308259605     46.71
Light Buffer                4312153575      2730173605     63.31
Vista Buffer                  10129503         7138130     70.47
Calls to Noise:          229477140   Calls to DNoise:             10
Shadow Ray Tests:       1745650454   Succeeded:            568607435
Reflected Rays:          288949856   Total Internal:       193644483
Refracted Rays:           66384846
Transmitted Rays:               14
Number of photons shot:           4992
Surface photons stored:         128759
Priority queue insert:     51590024944
Priority queue remove:     23904966790
Gather function called:      288832354
Smallest Alloc:                 10 bytes   Largest:           327688
Peak memory used:          3481630 bytes
Time For Photon:   0 hours  0 minutes  16.0 seconds (16 seconds)
Time For Trace:   68 hours 50 minutes  36.0 seconds (247836 seconds)
     Total Time:   68 hours 50 minutes  52.0 seconds (247852 seconds)
This is what I
changed:
#declare   PhotonCount = 29000;
added :
   light_source { < -7 , 10 , 20 > , rgb < 1,0,0> }
   light_source { <  2 , 10 , 10 > , rgb < 0,1,0> }
   light_source { < 14 , 10 ,  0 > , rgb < 0,0,1> }
changed:
   box          { <-15,-1,-15>, <15,0,15>
                 texture { Glass3 }
                 texture { Brass_Valley }
//                 pigment { rgb <.3,.4,.5> }
//                 finish  { ambient .3 diffuse .4 }
                  #if ( Photons ) photons { target 1 refraction off
reflection off } #end
Ger
Download 'diamonds2.jpg' (143 KB)
Preview of image 'diamonds2.jpg'
Subject: Re: Marc Champagne's diamonds again (150 Kb)
Date: 29 Mar 2003 23:01:30
Message: <Xns934DE9E3041ADPOVMIKA@204.213.191.226>
Ger <No.### [at] ThankYou> wrote in news:3e864f0d@news.povray.org:
..SNIP..
Outright colorfull, 68 hours... shesh you have much more
patience than I.
I guess it paid off to to creat these gems eh!
ciao
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Date: 30 Mar 2003 07:01:55
Message: <3e86dcb3$1@news.povray.org>
> ...SNIP..
> patience than I.
I kept the render running in the background on a Linux machine so it
didn't bother me all that much. If I hadn't done anything else on it
(the computer) the render might have finished a few hours earlier.
By the time I have my cluster up and running I hope the renders will go
a lot faster
Sure did
> ciao
Ger
Date: 30 Mar 2003 07:42:24
Message: <3e86e630$1@news.povray.org>
With a little bit of imagination, i can read 'P O V' in this pic...
.. or is it I need coffee ?...
Nice ones... wish i had that in my hands...
FD
Date: 30 Mar 2003 07:54:00
Message: <3e86e8e8$1@news.povray.org>
> ... or is it I need coffee ?...
I think you need coffee  :)
A good color printer will get you long ways  ;)
> FD
Ger
Date: 30 Mar 2003 08:20:20
Message: <Xns934E9C7D2B79Draf256com@204.213.191.226>
Very nice :) But imho - You should turn OFF reflection of plane/floor, and
make more uniform one-color floor - so that refracted photons stored on
floor would be more vissible
Date: 30 Mar 2003 08:28:40
Message: <3e86f108$1@news.povray.org>
Rafal 'Raf256' Maj wrote:
> Very nice :)
I did the reflective floor because of the sparkles I hoped one would see
on the floor.
You're right about the coloring of the floor, it should have been more
toned down but not nessesarely (hmmm spelling) one-color
Ger
Date: 30 Mar 2003 18:02:32
Message: <3e877788@news.povray.org>
I don't feel happy when I don't have *something* rendering at low priority
at my computer at home. So long renders that bring me something spectacular
(even an animation) are bliss because I can forget about it completely and
do faster renders that have higher process priority and finish faster.
Date: 30 Mar 2003 18:07:14
Message: <3e8778a2$1@news.povray.org>
I don't usually do multiple renders at the same computer. I just let one
render run and do other stuff on the computer in the mean time.
If I want to do another render I switch to another computer.
By the time I have the cluster up and running I can do multiple renders
from the same workstation
Ger
Date: 31 Mar 2003 00:53:06
Message: <Xns934F835CDB09badhabit07hotmaildot@204.213.191.226>
Dammit..... I see 'P O V' too..... Have to find a support group.... LOL
"Freddy D." <Fde### [at] SPAMSUCKSwanadoofr> wrote in news:3e86e630$1
@news.povray.org:
> FD
