A quick example to illustrate the finish maps in mlpov, here we use the same
map for specular and reflection but they could have been different.
Unfortunately the patch is far from complete (there are problems with
transformations, etc)
#declare fmap = function { pigment { image_map { jpeg "metal_44_s.jpg"
map_type 1 interpolate 2 } } }
#declare fmap_g = function { fmap(x,y,z).gray * 2 }
finish {
ambient .1
diffuse .6
specular fmap_g
reflection fmap
roughness .01
Download 'metal_44_s.jpg' (47 KB)
Download 'finish.jpg' (22 KB)
Preview of image 'metal_44_s.jpg'
Preview of image 'finish.jpg'
*blinks*
Hhhheyyyyyyy...
I wannit!
Tim Cook
Version: 3.12
I think we all do!
Is there any way to get it working with uv_mapping?
-Jide
yes, by adding the keyword "uv_mapping" in the finish
M
>finish {
> ambient .1
> diffuse .6
> specular fmap_g
> reflection fmap
> roughness .01
Yes, this looks very usefull! Actualy I wondered why there was no finish
map in the official release...
Thanks, it really does work!
I didn't think of adding it to the finish, I tried it in the pigment
function which didn't work (needless to say?)
-Jide
You need MegaPOV or MLpov.
I suggest the newest incarnation of MegaPOV:
http://www.schunter.etc.tu-bs.de/~chris/megapov/
(temporary link)
Hugo
Yeah, I know. I have MLPov
-Jide
3e686d42@news.povray.org...
same
Note that for those who can't wait for the patch, finish map effects can
already be done using image_pattern. The patch may have other advantages of
course.
G.
global_settings {assumed_gamma 1.0}
camera {location -z*4+y*0.5 direction 1.5*z right
x*image_width/image_height look_at <0.0, 0.0, 0.0>}
sky_sphere {pigment {gradient y color_map {[0.0 rgb <0.6,0.7,1.0>][0.7 rgb
<0.0,0.1,0.8>]}}}
light_source { 0, rgb 1 translate -z*50 rotate x*30 rotate y*-70}
light_source { 0, rgb 0.5 translate -z*50 rotate x*20 rotate y*50}
plane { y, -1 pigment { color rgb <0.7,0.5,0.3> }}
#declare N_Sphere=normal{
average
normal_map{
[2 bump_map{jpeg "metal_44_s.jpg" map_type 1 interpolate 2 }
bump_size 0.2]
[1 bumps 0.4 scale 1/100 ]
sphere {
0.0, 1
image_pattern{jpeg "metal_44_s.jpg" map_type 1 interpolate 2 }
texture_map{
[0 pigment{Red*0.1} normal{N_Sphere} finish{ambient 0 diffuse
0.6 specular 0.1 reflection 0 roughness 0.01}]
[0.001 pigment{White*0.1} normal{N_Sphere} finish{ambient 0
diffuse 0.6 specular 0.1 reflection 0 roughness 0.01}]
[0.2 pigment{White*0.5} normal{N_Sphere} finish{ambient 0
[0.6 pigment{White*0.5} normal{N_Sphere } finish{ambient 0
diffuse 0.6 specular 1 reflection {0.3,0.8} roughness 0.03}]
rotate y*20
http://www.oyonale.com
- Graphic experiments
- Posters
Download 'test_finishmap.jpg' (11 KB)
Preview of image 'test_finishmap.jpg'
