POV-Ray : Newsgroups : povray.binaries.images : Server Time
22 Dec 2025 20:20:47 EST (-0500)
   (Message 1 to 3 of 3)
Subject:
Date: 17 Feb 2003 11:52:55
Message: <3e511367@news.povray.org>
I'm definitely having problems getting this wall right!
The main problem is in rounding the edges of the bricks. As you can see by
my code (posted today in p.b.s-f), I'm creating the brick shape with a boxed
pattern, warped x & y (declaration line #96) then cloning the resultant
pattern (declared as a function line #114). This function is then used to
make a height-field.
So far, so good.
It seems obvious to me that the best way of rounding the basic brick shape
is by using a colour_map in the BrickShape pigment with a poly_wave
modifier. The gradation of pigment looks right when tested as a colour_map
on a plane, so why the *%!$! won't it give me a pleasantly rounded shape
when used in the height-field?
I have a horrible feeling that the problem might be tied up with the size of
the h-f (atm 1000x1000) but I'm already getting peak memory usage of 18 Meg
and on my machine (166 Mhz Pentium with 32 Meg Ram) that's heading for
frequent swapping (mem. usage seems to be exponentially linked with h-f
size).
Any comments or suggestions will be gratefully accepted.
BTW The existing code uses an image map (graffiti.png). You can simulate the
colour (the wall is supposed to be painted) by using rgb <0.99, 0.99, 0.824>
John
War is not good for children and other living things
Download 'OldBrickWall.jpg' (64 KB)
Preview of image 'OldBrickWall.jpg'
Subject:
Date: 17 Feb 2003 12:27:52
Message: <3e511b98$1@news.povray.org>
"Doctor John" <jgu### [at] netscapenet> wrote in message
news:3e511367@news.povray.org...
Looks like this would work easily as a normal, or an iso if necessary.
HF definitely not the way to go here.
 -Shay
Subject:
Date: 17 Feb 2003 13:13:28
Message: <3e512648$1@news.povray.org>
Normal, I've tried. Doesn't give the right effect. Isosurface did cross my
mind esp since I've got the function half-written, but (look at my machine
spec) I'll probably end up with massive rendering times.
John
