POV-Ray : Newsgroups : povray.binaries.images : Loss of colour in shadow when using photons. - a02a_1xb2.png Server Time
14 Apr 2026 09:42:48 EDT (-0400)
  Loss of colour in shadow when using photons. - a02a_1xb2.png (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Loss of colour in shadow when using photons. - a02a_1xb2.png
Date: 12 Nov 2004 16:19:41
Message: <Xns959FE37EC56A3raf256com@203.29.75.35>
mca### [at] aolcom news:8g9ap0p5b48db4qi39789e7h4dvfbr9sek@4ax.com
> Hmm, ior was set too low for both liquid and glass. The liquid is a
> solid :-) so I'll try a ripple noise pattern wank up the photons for
> caustics and let it run overnight.
Also YOu might
1) turn on radiosity
2) add scattering media to water and set media on in radiosity{}
http://www.raf256.com/3d/
Computer Graphics
Date: 12 Nov 2004 16:21:04
Message: <41952940@news.povray.org>
"Stephen McAvoy" <mca### [at] aolcom> wrote in message
news:8g9ap0p5b48db4qi39789e7h4dvfbr9sek@4ax.com...
> On Fri, 12 Nov 2004 15:23:55 -0500, "Slime" <fak### [at] emailaddress>
> wrote:
>....wank up the photons ....
<snigger>
Andy Cocker
Date: 12 Nov 2004 16:40:46
Message: <41952dde$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns959FE37EC56A3raf256com@203.29.75.35...
> Also YOu might
3) buy more whiskey.
Date: 12 Nov 2004 23:36:28
Message: <41958f4c$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote...
> > I do like a wee dram but I noticed that when I turned on photons the
> > whisky colour of the shadow went.
> This is physically correct. Any light passing through the glass becomes a
> photon. Notice that the photon-covered areas *are* colored, since that
light
> is filtered by the color of the drink. The rest of the shadow is uncolored
> because none of the light hitting that area has passed through the glass.
Correct.  It is interesting how our perception of our world often differs
from reality.  When I started working on the photon code, I started looking
more closely at real items in the real world, and I noticed that many
shadows of clear objects (such as a glass of water) looked very different
than how I thought they "should" look.  The reality is that much of the
shadow area is almost completely black.  However, when we casually view
something like a glass of water, if we don't look carefully, our brains have
a tendency to fill in details that really aren't there.
-Nathan
Date: 13 Nov 2004 04:15:25
Message: <4195d0ad@news.povray.org>
Ah yes - the mind does not always perceive what is before the eye...
(See any optical illusion for a simple proof of this concept.)
Personally, I would suggest that maybe the lightsource is in the wrong
place (and/or should be an area light - do photons respond to those?)
Andrew.
Date: 14 Nov 2004 02:31:46
Message: <0f2ep0talmad3vusl3t39iaaeiq6bqcj03@4ax.com>
On Fri, 12 Nov 2004 21:21:13 -0000, "Andy Cocker"
><snigger>
>Andy Cocker
Freudian slip or just getting senile :-)
Of course I meant "crank up the photons"
Regards
Date: 14 Nov 2004 05:44:23
Message: <bodep0peja2sfs93thlprttickj1hbohs0@4ax.com>
On Fri, 12 Nov 2004 16:40:40 -0500, "Ross" <rli### [at] everestkcnet>
That was the correct solution. By doing that I could see that Slime is
right on both counts. The unlit shadow (?) should be uncoloured and if
I reduce the ior to 1 then all of the shadow is coloured.
I would have bet a mars bar that the shadow should have been coloured
with intense caustics.
I'll do a bit more experimenting and post later.
Regards
Date: 14 Nov 2004 15:37:20
Message: <4197c200$1@news.povray.org>
Andrew the Orchid nous apporta ses lumieres ainsi en ce 2004-11-13
04:14... :
>> differs
>> looking
>> different
>> brains have
> Andrew.
You need to add "area_light on" in the light's photons block in addition
to the area_light in the light's deffinition. Otherwise, it will act as
a point light for the photons.
Date: 15 Nov 2004 05:22:23
Message: <4r0hp0paaptoacolc0qionj2h7o9v1sj7m@4ax.com>
On Sat, 13 Nov 2004 09:14:49 +0000, Andrew the Orchid <voi### [at] devnull>
Whilst I now agree that the shadow should be black/grey I am still
trying to fake it, out of perversity. Where do you suggest that the
light source should be situated? Why use an area light?
Regards
Subject: Re: Loss of colour in shadow when using photons. - a02a_1xb2.png - tray02j.jpg
Date: 21 Nov 2004 15:36:24
Message: <91v1q0pv53ij4gfgkt36a6ici3j70307r2@4ax.com>
Thanks for all your help, so have a little drink on me.
Regards
Download 'tray02j.jpg' (37 KB)
Preview of image 'tray02j.jpg'
