POV-Ray : Newsgroups : povray.binaries.images : Please help edumacate me... (HDRI-lighting settings) Server Time
27 Feb 2026 18:11:49 EST (-0500)
  Please help edumacate me... (HDRI-lighting settings) (Message 1 to 4 of 4)
Subject: Please help edumacate me... (HDRI-lighting settings)
Date: 15 Jan 2003 12:36:41
Message: <3e259c29@news.povray.org>
Please forgive the noob nature of this post, but I'd really like to
understand what is going on with HDRI-lit renderings.  In playing around
toward that end I took the standard MLPOV hdri.pov scene and put a disc in
like this:
disc {
  <0, 0, 0> y, 8.0, 0
  pigment { color rgb 1 }
  finish { ambient 0 diffuse 1 }
the resulting rendering is attached below as HDRI_disc.jpg  I wanted to have
more defined shadows, and so asked Alan Holding about the settings he used
in his very fine skeleton.jpg image ( located here:
http://news.povray.org/povray.binaries.images/29668/ )
I lifted his globals and stuck them into the HDRI_disc scene; here they are:
global_settings {
  radiosity {
    pretrace_start 0.16
    pretrace_end   0.01
    count 300
    nearest_count 3
    error_bound 0.1
    recursion_limit 1
    low_error_factor 1
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1  // was 1.2 in Alan's scene
    adc_bailout 0.01/2
    normal on
and the result is attached below as HDRI_disc_lichens.jpg  Strange dark
spots...photons?
Finally, by changing the "recursion limit" from 1 to 3 bright spots that
look an awful lot like refractive caustics appear.  This one is attached as
HDRI_lichens_caustics.jpg.
The Questions:
1) Based on the orignal HDRI_disc.pov, what I settings do I need to change
just to get smoother, more believable shadows?  Setting low_error_factor
lower smooths the shadows, but doesn't touch the spots...
2) What *are* those dark spots?  How do I make them either go away or
resolve into something more attractive?
3) Are those really caustics?  How can I eliminate them?  How can I refine
them?
4) The contrast in the upper right of the middle sphere is exceptionally low
in the two later images--any idea why?
Thanks for your patience--RTFM responses completely welcome, especially if
they come with section numbers!
-Chad
Download 'HDRI_disc_lichens_caustics.jpg' (36 KB) Download 'HDRI_disc_lichens.jpg' (32 KB) Download 'HDRI_disc.jpg' (24 KB)
Preview of image 'HDRI_disc_lichens_caustics.jpg'
Preview of image 'HDRI_disc_lichens.jpg'
Preview of image 'HDRI_disc.jpg'
Subject: Re: Please help edumacate me... (HDRI-lighting settings)
Date: 15 Jan 2003 16:56:15
Message: <3e25d8ff@news.povray.org>
"Chad" <ceb### [at] druryedu> wrote in message news:3e259c29@news.povray.org...
count 300 could be higher probably. If you raise error_bound toward 1.0
things will blend out too but then details are lost. At least that's all I
have to say on this.
Farewell,
Date: 15 Jan 2003 17:25:04
Message: <web.3e25df148080f8bece0a45b30@news.povray.org>
Try changing the sphere's diffuse value to 1, or make the pigment brighter
than 1.  It seems that sometimes radiosity will not brighten a surface past
diffuse*pigment, no matter how bright the surroundings.  Increasing
max_sample doesn't seem to help either.  Is this a bug?
Date: 16 Jan 2003 08:20:09
Message: <3e26b189$1@news.povray.org>
This is a max_trace_level problem. If you put "max_trace_level 50" in
the global_settings block they should go away.
I'd also increase the counts somewhat and the nearest_count to at least 5.
Bye for now,
	Mike Andrews.
