Please forgive the noob nature of this post, but I'd really like to
understand what is going on with HDRI-lit renderings. In playing around
toward that end I took the standard MLPOV hdri.pov scene and put a disc in
like this:
disc {
<0, 0, 0> y, 8.0, 0
pigment { color rgb 1 }
finish { ambient 0 diffuse 1 }
the resulting rendering is attached below as HDRI_disc.jpg I wanted to have
more defined shadows, and so asked Alan Holding about the settings he used
in his very fine skeleton.jpg image ( located here:
http://news.povray.org/povray.binaries.images/29668/ )
I lifted his globals and stuck them into the HDRI_disc scene; here they are:
global_settings {
radiosity {
pretrace_start 0.16
pretrace_end 0.01
count 300
nearest_count 3
error_bound 0.1
recursion_limit 1
low_error_factor 1
gray_threshold 0.0
minimum_reuse 0.015
brightness 1 // was 1.2 in Alan's scene
adc_bailout 0.01/2
normal on
and the result is attached below as HDRI_disc_lichens.jpg Strange dark
spots...photons?
Finally, by changing the "recursion limit" from 1 to 3 bright spots that
look an awful lot like refractive caustics appear. This one is attached as
HDRI_lichens_caustics.jpg.
The Questions:
1) Based on the orignal HDRI_disc.pov, what I settings do I need to change
just to get smoother, more believable shadows? Setting low_error_factor
lower smooths the shadows, but doesn't touch the spots...
2) What *are* those dark spots? How do I make them either go away or
resolve into something more attractive?
3) Are those really caustics? How can I eliminate them? How can I refine
them?
4) The contrast in the upper right of the middle sphere is exceptionally low
in the two later images--any idea why?
Thanks for your patience--RTFM responses completely welcome, especially if
they come with section numbers!
-Chad
Download 'HDRI_disc_lichens_caustics.jpg' (36 KB)
Download 'HDRI_disc_lichens.jpg' (32 KB)
Download 'HDRI_disc.jpg' (24 KB)
Preview of image 'HDRI_disc_lichens_caustics.jpg'
Preview of image 'HDRI_disc_lichens.jpg'
Preview of image 'HDRI_disc.jpg'
