POV-Ray : Newsgroups : povray.binaries.images : randomish (~38K) Server Time
22 Apr 2026 00:07:44 EDT (-0400)
  randomish (~38K) (Message 1 to 8 of 8)
Subject: randomish (~38K)
Date: 7 Jan 2003 07:44:38
Message: <3e1acbb6@news.povray.org>
I was playing around with generating geometric shapes using random
numbers constrained by certain conditions.
This one uses the following algorithm
start with a point in space
while n < some_number
   add plus or minus one to one of x,y or z
   if the new point is within a certain volume ( in this case, near
the 		    surface of a sphere)
   add the new point and a cylinder connecting this and the previous
     point
I'm using Python to do the calcs and output a pov file, since it's much
faster that way and easier to keep track of which points are occupied
and which pairs are connected.
Anyway I thought this one looked niceish with most of the allowed
segments in place.
Download 'pipes.jpg' (38 KB)
Preview of image 'pipes.jpg'
Subject: Re: randomish (~38K)
Date: 7 Jan 2003 13:24:52
Message: <3e1b1b74$1@news.povray.org>
hey!
this is really nice. i love this background/lightning/whatsoever. how did
you do it? media?
greetings:florian
Date: 8 Jan 2003 04:05:35
Message: <3E1BECB3.30708@alphalink.com.au>
>     point
Do you have other constraints - like the number of times a point may be
visited? It would be interesting to see if it could fill much of the
volume if you only let it visit each point once.
Date: 8 Jan 2003 06:59:43
Message: <pan.2003.01.08.11.59.41.263190@internode.on.net>
>>   add plus or minus one to one of x,y or z if the new point is within a
>>     point
At the moment it will go to any of the adjacent points regardless but tags
the point as having a sphere and the two points as having a cylinder so
that only one object will be created.
I'll have to try only visiting empty points.  I suspect that large areas
would become 'walled off' unless a lot of the volume was allowed to be
used.
Date: 8 Jan 2003 07:13:31
Message: <3E1C18BE.80607@alphalink.com.au>
> used.
Yes I imagine so. Perhaps you could make some kind of simple re-routing
routine such that if your pipe layer got stuck he could find out if any
of the blocking pipes were trivially re-routable, and if so, move them
to a different route to allow the pipeline to continue on through.
I can't imagine why you would bother, but it might be fun.
Date: 8 Jan 2003 09:30:30
Message: <3e1c3606$1@news.povray.org>
i tried to do something similar - i wrote a macro which would make a random
path through a rectangular area (only 4 directions, left, up, right, down).
it was for creating a maze afterwards. i used a recursive method, as to have
the chance to avoid dead ends. it came out that the recursion level got to
deep very fast. pov only allows 200 nested conditionals, which was far too
little... (perhaps only my code was that bad? *g*)
but in your case it could be done. perhaps you should allow to reuse a point
if a dead end is reached...
greetings:florian
Date: 9 Jan 2003 00:18:40
Message: <3e1d0630@news.povray.org>
Very sweet me likes : )
Date: 9 Jan 2003 06:52:44
Message: <pan.2003.01.09.11.52.42.11283@internode.on.net>
>> tags the point as having a sphere and the two points as having a
>> cylinder so that only one object will be created.
>> used.
> routine such that if your pipe layer got stuck he could find out if any of
> the blocking pipes were trivially re-routable, and if so, move them to a
Yeah, maybe. I only took about 10 minutes writing the code to do this
algorithm and maybe an hour playing around with various constraints.
I might look into some more complex routing stuff some time.
Another idea I had was to make an animation where the pipes are added one
at a time, maybe with each pipe growing from the start to the end point.
In fact that idea sounds really simple, I might start on that now :)
