POV-Ray : Newsgroups : povray.binaries.images : reflective caustics with radiosity Server Time
13 May 2026 22:52:05 EDT (-0400)
  reflective caustics with radiosity (Message 1 to 10 of 12)
Subject: reflective caustics with radiosity
Date: 29 Dec 2002 11:10:51
Message: <3e0f1e8b@news.povray.org>
First the radiosity-version, then the photon_map-version.
It seems like radiosity does take IOR and reflection into account..
cool :)
What we need now, is a way to "direct" the radiosity samples, so samples
will only be taken in the direction of other objects.  (Wouldn't be of much
use when a sky sphere is used though...)
cu!
ZK AKA SaD
http://www.povplace.be.tf
"The only thing that helps me maintain my slender grip on reality is the
friendship I share with my collection of singing potatoes."
Download 'photonsradiosity3.jpg' (8 KB) Download 'photonsradiosity4.jpg' (9 KB)
Preview of image 'photonsradiosity3.jpg'
Preview of image 'photonsradiosity4.jpg'
Subject: Re: reflective caustics with radiosity
Date: 29 Dec 2002 20:55:02
Message: <web.3e0fa5e4be56d4eb978071460@news.povray.org>
>cool :)
All this is pretty interesting and all, but I doubt it's got practical
applications. If you want HDRI and photons and no light_sources just render
a first version with light_sources and use save_file in the photons block
(you can stop the render just after building the photon map, you don't need
actually render the scene). Then get rid of the lightsource/sources and
change save_file with load_file. Simple as that. I haven't followed all
this discussion so I apology if this was already suggested.
Jonathan.
Date: 29 Dec 2002 21:35:11
Message: <3e0fb0df$1@news.povray.org>
"JRG" <jrg### [at] hotmailcom> schreef in bericht
news:web.3e0fa5e4be56d4eb978071460@news.povray.org...
I dind't know you could save photons :)
But actually these images were just a test to see if radiosity takes reflection
and ior into account, which it does :)
cu!
Date: 29 Dec 2002 21:48:25
Message: <3e0fb3f9$1@news.povray.org>
This is where I disagree with POV-Ray's radiosity implementation.
Radiosity is for simulating diffuse interreflection. Simulating specular
interactions during the process of shooting radiosity rays is a waste and is
better done using POV-Ray's excellent photon mapping. Fortunately this was
easy to fix. I did it in my own personal patch, and it has resulted in some
nice speedups when doing two-pass renders (in scenes that contain
reflections etc). :)
George
reflection
Date: 29 Dec 2002 21:57:40
Message: <3e0fb624$1@news.povray.org>
This is IMHO :) I do appreciate all the work of the POV-Ray developers and
community, of course!
George
"George Pantazopoulos" <the### [at] attbicom*KILLSPAM*> wrote in message
news:3e0fb3f9$1@news.povray.org...
is
some
> George
> reflection
Date: 29 Dec 2002 21:58:35
Message: <3e0fb65b$1@news.povray.org>
Could you show some example pictures so wel can compare the results of the
regular 3.5 images with those of your patch? IMHO there is a very thin line
between diffuse interreflection and "normal" interreflection.
Date: 29 Dec 2002 22:03:37
Message: <3e0fb789@news.povray.org>
Here is a more formal test I did a couple of months ago (before school got
really hectic :) )
George
http://home.attbi.com/~themaxx/povray/xrtest.html
"Apache" <apa### [at] yahoocom> wrote in message
news:3e0fb65b$1@news.povray.org...
line
Date: 29 Dec 2002 22:10:22
Message: <3e0fb91e$1@news.povray.org>
"George Pantazopoulos" <the### [at] attbicom*KILLSPAM*> schreef in bericht
> George
Hmm, I disagree actually.  For example: take a room with a light source (a
bright object, it won't work with a real light_source) and a mirror.  An object
in that room should have 2 shadows: one from the real light source, and one from
the virtual light source, the reflection of the real light source.  Using
radiosity as it is now, you can simulate this behaviour, but this isn't possible
in any way if radiosity doesn't take reflections into account.
I realise it would be mostly unnoticable effects, but I believe it's those
effects that makes a difference between a photorealistic rendering and an
obvious synthetic image.
cu!
Date: 29 Dec 2002 22:37:26
Message: <3e0fbf76$1@news.povray.org>
I just started a "faked photons" radiosity scene....
Date: 30 Dec 2002 19:46:34
Message: <3e10e8ea@news.povray.org>
Actually, these two situations solve similar but different parts of the
global illumination problem.  Photons in POV only solve light transport from
light_source objects to the first diffuse surface.  POV's photons stop when
they hit a diffuse surface.  POV's radiosity, on the other hand, tracks
light transport from diffuse (or ambient) surfaces to other diffuse
surfaces.  Along the way, the light might be reflected or refracted.
Basically, POV's radiosity picks up where photons and direct lighting stop.
Because of this, using photons and HRDI together with the suggested method
(save_file and load_file) will provide an inaccurate (though probably
good-looking) render, because you would be using both photons and radiosity
to solve the same part of the light transport model.
-Nathan
"George Pantazopoulos" <the### [at] attbicom*KILLSPAM*> wrote...
is
some
> George
> reflection
