POV-Ray : Newsgroups : povray.binaries.images : caustics with radiosity? Server Time
27 Feb 2026 19:46:15 EST (-0500)
  caustics with radiosity? (Message 1 to 10 of 18)
Subject: caustics with radiosity?
Date: 28 Dec 2002 22:55:44
Message: <3e0e7240$1@news.povray.org>
It seems to be more or less possible.
Why is there an upper-limit of 1600 for radiosity-samples?
cu!
ZK AKA SaD
http://www.povplace.be.tf
"Luckyly they included a button, right here, that'll blow the entire thing
up!"
Download 'photonsradiosity.jpg' (5 KB)
Preview of image 'photonsradiosity.jpg'
Subject: Re: caustics with radiosity?
Date: 28 Dec 2002 23:05:45
Message: <3e0e7499@news.povray.org>
reproduction of the image using photons...
cu!
ZK AKA SaD
"Wisdom must be gathered, it cannot be given."
Download 'photonsradiosity2.jpg' (5 KB)
Preview of image 'photonsradiosity2.jpg'
Date: 29 Dec 2002 00:45:03
Message: <web.3e0e8b5643114ef05798b2cc0@news.povray.org>
It seems very, very, dark.
*** http://www.highpoly3d.com ***
*** Tutorials/Textures/Forums ***
Date: 29 Dec 2002 01:30:38
Message: <Xns92F34C1E96F36raf256com@204.213.191.226>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in
news:3e0e7240$1@news.povray.org
Many small black dots on top and base of this cylinder is an error, move
Your's glass i.e.:
  translate -y*0.00001
Date: 29 Dec 2002 07:36:58
Message: <3E0EEC6A.7B42D7F9@gmx.de>
Because it uses a fixed table for the sample directions.  If you know a
way for generating an arbitrary number of sample directions on the fly
with random yet uniform distribution (and cos theta density distribution)
you are welcome to share it... ;-)
Last updated 07 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 29 Dec 2002 07:44:49
Message: <Xns92F38B8FF3898raf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3E0EEC6A.7B42D7F9@gmx.de
Algorithm that was used to generate 1600 elements fixed array - can it be
used to generate i.e. 20,000 fixed elements array ?
Date: 29 Dec 2002 08:39:04
Message: <3e0efaf8@news.povray.org>
> Your's glass i.e.:
I know :-)
cu!
ZK AKA SaD
"It's our lot in life. It's not a lot, but it's our life."
Date: 29 Dec 2002 08:40:45
Message: <3e0efb5d@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> schreef in bericht
news:3E0EEC6A.7B42D7F9@gmx.de...
Why is a fixed table necessary?
cu!
ZK AKA SaD
"I won't bite... hard."
Date: 29 Dec 2002 10:31:58
Message: <3E0F156E.AB321B83@gmx.de>
Have you read what i wrote?
I don't know a method to generate such a distribution in high quality that
would be fast enough to be run before every render - if you do feel free
to implement it.
Date: 29 Dec 2002 10:40:53
Message: <3e0f1785@news.povray.org>
Actually, that's easy, if I understand the question correctly: let (x, y) be
a random point in the unit circle (x^2 + y^2 <= 1), and let z = sqrt(1 -
x^2 - y^2).
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
