POV-Ray : Newsgroups : povray.binaries.images : Mesh2-based sphere sweep replacement Server Time
23 Jun 2026 12:57:52 EDT (-0400)
  Mesh2-based sphere sweep replacement (Message 1 to 5 of 5)
Subject: Mesh2-based sphere sweep replacement
Date: 20 Dec 2002 15:39:57
Message: <3e03801d@news.povray.org>
You can dial in the smoothness .
Download 'sweepz09.JPG' (29 KB)
Preview of image 'sweepz09.JPG'
Subject: Re: Mesh2-based sphere sweep replacement
Date: 20 Dec 2002 16:55:17
Message: <3e0391c5$1@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> wrote in message
news:3e03801d@news.povray.org...
Good start, but needs surface normals bad. Can the spheres which define the
sweep be of different radii? Does the sweep pinch, or is this just an
illusion?
 -Shay
Date: 21 Dec 2002 13:50:04
Message: <3e04b7dc$1@news.povray.org>
The cross section will always be a "disk" perpendicular to the path of the
spline-- I think this is what you observed.
It is possible to get rid of the truncated look by simply choosing a finer
triangle size.  Were you simply pointing out the truncated look, or is there
a real benefit to adding surface normals?
"Shay" <sah### [at] simcopartscom> wrote in message
news:3e0391c5$1@news.povray.org...
the
> illusion?
>  -Shay
Date: 23 Dec 2002 10:49:59
Message: <3e0730a7$1@news.povray.org>
"Greg M. Johnson" <gregj:-)56590@ao:-)l.com> wrote in message
news:3e04b7dc$1@news.povray.org...
It appears that this is not the case, but I guess it's just an optical
illusion.
there
The benefit is that an almost identical picture could be made with only
about ten rows of triangles. Your method of using tiny, pixel-sized
triangles to achieve smoothness will slow down the render and not allow
giant sweeps due to lack of memory.
 -Shay
Date: 23 Dec 2002 23:57:20
Message: <3e07e930$1@news.povray.org>
news:3e0730a7$1@news.povray.org...
Wow.  The things you learn.  I suppose I can try to add this to the algo....
