POV-Ray : Newsgroups : povray.binaries.images : Fluorescent strip radiosity test scene (22K + 24K) Server Time
10 Jan 2026 17:34:21 EST (-0500)
  Fluorescent strip radiosity test scene (22K + 24K) (Message 1 to 8 of 8)
Subject: Fluorescent strip radiosity test scene (22K + 24K)
Date: 28 Nov 2002 08:11:18
Message: <3de615f6@news.povray.org>
Hi Folks,
This is a simple test scene to see how well PoV handles radiosity
lighting by long thin ambient sources - effectively fluorescent strip
lighting.
The two images are
room_orig.jpg - uses standard WinPoV 3.5
room_mod.jpg  - uses a radiosity modified personal compile of 3.5
Both use scene posted in p.b.s-f.
See the thread in p.a-u as well.
Comments please?
Bye for now,
     Mike Andrews.
Download 'room_orig.jpg' (24 KB) Download 'room_mod.jpg' (22 KB)
Preview of image 'room_orig.jpg'
Preview of image 'room_mod.jpg'
Subject: Re: Fluorescent strip radiosity test scene (22K + 24K)
Date: 28 Nov 2002 08:41:01
Message: <3de61ced@news.povray.org>
"Michael Andrews" <m.c### [at] readingacuk> wrote in message
news:3de615f6@news.povray.org...
> lighting.
Hmmm. Those are very different alright. However... I just tried a test run
of your scene script and using a count of 400 (much faster than at 1600) and
error_bound 1.0 it looks okay too. So, guess what I'm wondering is, how is
your patched POV better than using other values in the official POV? I
realize of course that the settings I used might not work out for other
renders, plus I only checked with a tiny resolution to see it quicker.
Date: 28 Nov 2002 08:53:19
Message: <3de61fcf$1@news.povray.org>
What were the running times on each? (the second one does look much better)
Pentahall (formerly quadhall, formerly treshall)
> Hi Folks,
> lighting.
> The two images are
> Comments please?
> Bye for now,
>      Mike Andrews.
Date: 28 Nov 2002 09:24:06
Message: <3de62706$1@news.povray.org>
This looks promising! I read your post in advanced-users, but I'm not sure I
understand the sideeffect of your patch. Could you post an image where it
goes wrong (I know.. strange request) and more images to demonstrate how
well it behaves. What about spherical light sources? ... I won't set my
hopes too high, but on the other hand... :o)
Best regards,
Hugo
Date: 28 Nov 2002 10:41:03
Message: <3de6390f$1@news.povray.org>
Using a high error_bound will smooth out a lot of the noise, but also
smears the shadows.
I've attached a cropped piece of the same scene run with
   radiosity {
     pretrace_start 16/image_width
     pretrace_end   2/image_width
     count 400
     nearest_count 15
     error_bound 1
     recursion_limit 2
     low_error_factor .2
     gray_threshold 0.0
     minimum_reuse 0.001
     brightness 1
     adc_bailout 0.01/30
     max_sample 30
     normal on
The flat surfaces look nice and smooth, but compare the shadows around
the chairs to those in the previous images I posted - you'll see that
the lower error_bound gives a sharp shaddow edge which you would expect
to get from a light like this.
Mike Andrews.
Date: 28 Nov 2002 12:21:40
Message: <3de650a4@news.povray.org>
Errrm ... and now the image ... 8-/
Mike.
Download 'room_high_ef.jpg' (4 KB)
Preview of image 'room_high_ef.jpg'
Date: 28 Nov 2002 12:39:08
Message: <3de654bc$1@news.povray.org>
Okay, thanks. Yeah, that shows an improvement as well. As did the first
message posting did already, but I had to try and be a skeptic. Sure hope
your fix proves good all around. And, if so, that it can be incorporated
into POV-Ray.
Date: 28 Nov 2002 13:15:17
Message: <3de65d35$1@news.povray.org>
> into POV-Ray.
Thanks. It's not really a 'fix' though because the radiosity code isn't
really 'broken'. It's just that under some specific conditions I've
tried (ie small radiosity light sources) it can give an improvement.
I'll try to get a proper patch together at the weekend.
Mike Andrews.
