This is something I did a while ago - not a great render I'm afraid. A
higher resolution jpg and an animation are available at.
http://www.chris-j.co.uk/arm/arm.jpg
and
http://www.chris-j.co.uk/arm/arm.mpg
The animation is done with inverse kinematics. Perhaps the most interesing
part is my flexible pipes macro (soon to be posted in the advanced-users
group) which creates a curved pipe of a specified length between two end
points. This is especially useful in animation, where I've found pipes can
seem to stretch and move in unconvincing ways.
The rust texture isn't very good - does anyone know of a better one?
-Chris Johnson
Download 'armlow.jpg' (39 KB)
Preview of image 'armlow.jpg'
"Chris Johnson" <chr### [at] chris-j co uk> schreef in bericht
news:3dc50132@news.povray.org...
Exsqueeze me??? Baking powder???
Not a great render???
Man, you're insulting my renders! :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
I like the rust texture, but if you want something else you can try
this. (I included an example scene with source, too)
#declare MaskSubTex_1 =
texture{
pigment{
rgb 1 //.1
finish{
metallic
diffuse .7
specular .5
roughness .001
reflection .17
brilliance 4.8
normal{MaskNormal}
#declare MaskSubTex_2 =
texture{
pigment{
rgb <.95*1, 1, .95>//*.91
finish{
metallic
diffuse .5
specular (.1 + .5) / 2
roughness (.1 + .001) / 2
reflection .06
brilliance (2.8 + 4.8) / 2
normal{MaskNormal}
#declare MaskTex_1 = //Metal
texture{
dents
scale 1.45
turbulence .6
texture_map{
[0.0 MaskSubTex_1 scale 1]
//[0.05 MaskSubTex_1]
[0.85 MaskSubTex_2 scale 1]
[1 MaskSubTex_2 scale 1]
#declare MaskTex_2 = //Rust
texture{
pigment{
bozo
color_map{
[0 rgb <1, .9, .8>/1.05/1.2]
[1 rgb <1, .85, .8>/1.25/1.3]
scale .25
finish{
metallic
specular .1-.05
roughness .006
//reflection .02
brilliance 4
normal{
bumps -.3
scale <.02, .04, .04>
Download 'untitled2.jpg' (63 KB)
Download 'us-ascii' (7 KB)
Preview of image 'untitled2.jpg'
Oh, and one thing that I think is rather important to make rust look
good is the placement. YOu might want to try a material_map so that you
have full control over where the rust patches are.
/ martin
"Chris Johnson" <chr### [at] chris-j co uk> wrote in message
Here's a great rust texture that Xplo Aristotle posted a long time ago. It
renders pretty slowly but it looks realistic. The texture you're using now
looks fine to me, by the way...
file://Iron, Rust, and RustyIron by Xplo Aristotle
#local Iron = texture {
pigment {color rgb .25}
normal {granite .3 scale .2}
finish {roughness .01 specular .5 reflection .05 diffuse .8}
} file://texture
#local Rust = texture {
granite
color_map {
[0.0 rgb <0.809995, 0.299123, 0.113405> * .8]
[0.4 rgb <0.209995, 0.096941, 0.031510> * 1.2]
[0.6 rgb <0.209995, 0.096941, 0.031510> * 1.2]
[1.0 rgb <0.569986, 0.052720, 0.005707> * .9]
} file://color_map
scale .5
turbulence 1
} file://pigment
normal {wrinkles}
} file://texture
#local RustyIron = texture {
bozo
texture_map {
[0 Rust]
[.9 Iron]
[1 Iron]
} file://texture_map
turbulence 1
omega .3
lambda 4
} file://texture
-David
I like it, too. It looks fantastic!
Andreas
hey all..
this is *fantastic*. i love it.
you got a really nice level of details, and your pipes are *wow*!
there are few realistic images which make it into my wallpaper-folder, but
this one is far too cool to miss..
keep up the good work,
florian
Very nice design and details! You might want to try Anti-Alias without
jittering for the hence in the animation. To avoid flickering.
Hugo
