In this picture, I included my jelly fish model in a previous sea scene. And
it seems that the jelly fish media disappeared.
Sea is a simple clear hollow box, including interior with IOR set to 1.31
and an absobtion media.
Jellyfish are ISO CSG hollow objects, including interior definition with IOR
set to 1.31*1.05 plus scattering and emission media. It works when the jelly
fish is rendered alone (in this case no external box, and internal IOR set
to 1.05).
What is wrong in this description?
Does the jelly fish IOR works in the same way than a 1.05 IOR in the air?
Another question to pov gurus. The time to render this picture was so slow
that I have had to stop and continue rendering several time. Unfortunatly -
or fortunatly ? - I made a modification in the source witch changed the
position of the fish school. So I stored the result in a backup file and
rerender the part of the image tht was wrong: same settings, same machine.
What is strange is that the rendering speed went from 3 to 4 pixels per
second to 250 for the same part of the screen! My PC has few DRAM (128 meg)
for both POV and XP, is it the explanation? I don't understand why in that
case the memory need is decreasing, but if it is correct, it may be a way to
speed up rendering. Does it works with photons?
Chaps.
Download 'fish3.jpg' (84 KB)
Preview of image 'fish3.jpg'
Stupid question but are you sure that your water is hollow?
I have checked the code, it's hollow - the box, not the code :o)
Chaps
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3db831bd$1@news.povray.org...
And
"chaps" <cha### [at] yahoocom> wrote in message
news:3db8304d@news.povray.org...
air?
Your jellyfish looks like it's made of glass! :)
You're right, when redered alone it looks like this.
Chaps.
Download 'meduse3.jpg' (24 KB)
Preview of image 'meduse3.jpg'
Subject: Re: Sea WIP: advices about media are welcome!
Date: 24 Oct 2002 14:57:25
Message: <3db84295$1@news.povray.org>
And
Hollow object with media in a hollow object with media means the inner
object gets both medias inside.
See hollow2.pov in ./scenes/interior/media/
You can replace the third sphere with this code to clearly see the effect :
=== Begin sdl code ===
// Hollow, translucent sphere enclosed by media.
sphere {<29, 20, 0>, 25
pigment { rgbt <1, 1, 1, 0.9> }
finish {
ambient 0.0
diffuse 0.0
phong 1.0
phong_size 200
interior { ior 1.1 media{absorption 1 density{dents} }
hollow yes
=== End sdl code ===
The solution is to difference your sea object with an invisible clone of
your jellyfishes - beware of coincident surfaces...
I hope this helps.
Povingly,
Philippe
