POV-Ray : Newsgroups : povray.binaries.images : library sans photons Server Time
23 Dec 2025 15:31:23 EST (-0500)
  library sans photons (Message 1 to 5 of 5)
Subject: library sans photons
Date: 23 Oct 2002 21:52:37
Message: <3db75265@news.povray.org>
Scene contains 1470 frame level objects; 0 infinite.
Statistics for library.pov, Resolution 640 x 480
Pixels:          307200   Samples:         4919681   Smpls/Pxl: 16.01
Rays:           6136598   Saved:             19866   Max Level: 10/10
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                         7713082913      4534554591     58.79
Cone/Cylinder               3319420352      2051661845     61.81
CSG Intersection            3243288246      2569000209     79.21
CSG Merge                    518254970        45714655      8.82
Lathe                        847786747       513492061     60.57
Lathe Bound                  847786747       705129007     83.17
Prism                          1177477          115020      9.77
Prism Bound                    5179219         3795831     73.29
Sphere                      2287707332      1877235584     82.06
Torus                        250445366        21951192      8.76
Torus Bound                  250445366        29221013     11.67
Bounding Box               97061836031     33375321800     34.39
Vista Buffer                  96302012        62301820     64.69
Roots tested:           1102266579   eliminated:             3538073
Calls to Noise:          673973056   Calls to DNoise:      732140013
Media Intervals:        1286949414   Media Samples:      16730546353 (13.00)
Shadow Ray Tests:       3010933794   Succeeded:           1427123886
Reflected Rays:             197542   Total Internal:            1245
Refracted Rays:             666529
Transmitted Rays:           352846
Smallest Alloc:                 25 bytes   Largest:            61488
Peak memory used:          3647259 bytes
Time For Trace:   19 hours 19 minutes  42.0 seconds (69581 seconds)
     Total Time:   19 hours 19 minutes  41.0 seconds (69581 seconds)
CPU time used: kernel 10.75 seconds, user 61089.75 seconds, total
61100.50 seconds
Render averaged 5.03 PPS over 307200 pixels
Tim Cook
Version: 3.12
Download 'library.jpg' (43 KB)
Preview of image 'library.jpg'
Subject: Re: library sans photons
Date: 24 Oct 2002 13:43:37
Message: <3db83149@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3db75265@news.povray.org...
       To me, the candle flames seem to be too 'seethrough'. Also, would that wall
light really be just above the centre of the door? I think it should be higher.
    Nice though, I like.
   ~Steve~
Date: 24 Oct 2002 14:25:51
Message: <3db83b2f@news.povray.org>
wall light is 54" above floor, door is 78" tall
Tim Cook
Version: 3.12
Date: 24 Oct 2002 14:52:15
Message: <3db8415f$1@news.povray.org>
news:3db83b2f@news.povray.org...
wall
higher.
    Granted, but if that door is a standard 78" door, then the light still *looks*
chest height to me. I still think it should be higher so that it's above head
height. Sowweee...
         ~Steve~
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 24 Oct 2002 15:27:59
Message: <3db849bf@news.povray.org>
> height. Sowweee...
Oh!  It is chest-height...ish.  But you meant higher as in 'above head
level', I had thought you meand 'a few inches higher'. hehe
Still...above head level doesn't do much good as most of the light
from the lamp is directed upwards and some to the sides.
Tim Cook
Version: 3.12
