POV-Ray : Newsgroups : povray.binaries.images : Moebius Mechanism Server Time
28 Oct 2024 13:23:26 EDT (-0400)
  Moebius Mechanism (Message 1 to 10 of 16)
Subject: Moebius Mechanism
Date: 16 Oct 2002 17:08:06
Message: <3dadd536@news.povray.org>
I was reading about Moebius strips on Mathworld
(http://mathworld.wolfram.com/), and I was rather taken with the
animation on the page.  Here's my take on the construction.
Render time was ~2 hours @ 1280x960 on a 2GHz Athlon.  Needless to say
an animation may be a while coming...
Download 'Moebius.jpg' (61 KB)
Preview of image 'Moebius.jpg'
Subject: Re: Moebius Mechanism
Date: 16 Oct 2002 17:24:04
Message: <3dadd8f4$1@news.povray.org>
The colors are brilliant! I like. The gears seem a little strangely shaped,
though; it's obvious the ridges were made by cutting cylinders out of them.
 - Slime
[ http://www.slimeland.com/ ]
Date: 17 Oct 2002 06:17:12
Message: <3dae8e28@news.povray.org>
Blimey... That's a bit of a long render time isn't it? Especially for such a
high spec machine...
But anyway, the result seems to have been worth the wait! I like the
colours, and the whole image has a nice balanced feel to it.
Keep it up!
Andrew.
Date: 17 Oct 2002 07:07:17
Message: <3dae99e5$1@news.povray.org>
"Andrew Coppin" <orp### [at] btinternetcom> wrote in message
news:3dae8e28@news.povray.org...
I wouldn't have thought so, not when high quality focal blur is used.
All the best,
Andy Cocker
Date: 17 Oct 2002 07:39:14
Message: <3daea162@news.povray.org>
Ah - didn't notice the focal blur! Suddenly everything is clear... ;-)
Andrew.
Date: 17 Oct 2002 09:01:06
Message: <3daeb492$1@news.povray.org>
Yes, blur_samples 125 variance 0.001.  Otherwise it's nice and fast.
news:3daea162@news.povray.org...
> Andrew.
Date: 17 Oct 2002 09:02:47
Message: <3daeb4f7@news.povray.org>
Thanks!  I agree about the gears - these were only meant as
placeholders, but when it came to making "real" ones, I found I had no
idea what actual cogs really look like in detail!  Maybe it's time to
take apart some clocks...
"Slime" <slm### [at] slimelandcom> wrote in message
news:3dadd8f4$1@news.povray.org...
shaped,
them.
>  - Slime
Date: 17 Oct 2002 09:16:25
Message: <3daeb829@news.povray.org>
"Andrew" <ast### [at] hotmailcom> wrote in message
news:3dadd536@news.povray.org...
Neato. Perhaps gear-mess.zip may help
http://www.wozzeck.net/images/gear-mess.html
There's also a gear macro around, for pov 3.0 but not a problem for
3.1+ I believe. I have it archived around somewhere if you want.
Small brass clock type gears usualy have a brushed satin finish on
them. Would make yours look even better :)
Alf
Date: 17 Oct 2002 15:23:09
Message: <MPG.18191e93c52ba27e989bf3@news.povray.org>
However, you'd only need to do 1/20th of a rotation and loop it...
Jamie.
Date: 17 Oct 2002 15:43:37
Message: <3daf12e9@news.povray.org>
Hope this help.. just a quick 'thing'.. :)
FD
Mode { NOSPAM } = On ;
// Begin copy
#declare Gear =
object {
  union {
    // Main
    difference {
      cylinder { <0,0,-0.2> <0,0,0.2> 0.5 }
      cylinder { <0,0,-1.0> <0,0,1.0> 0.15 }
      cylinder { <0,0,-1.0> <0,0,-0.1> 0.36 }
      cylinder { <0,0,0.1> <0,0,1> 0.36 }
      cylinder { <0,0,-1> <0,0,-0.14> 0.4 }
      cylinder { <0,0,0.14> <0,0,1> 0.4 }
      torus { 0.36,0.04 rotate <90,0,0> translate <0,0,-0.14> }
      torus { 0.36,0.04 rotate <90,0,0> translate <0,0,0.14> }
    // Axle
    difference {
      cylinder { <0,0,-0.2> <0,0,0.2> 0.2 }
      cylinder { <0,0,-1.0> <0,0,1.0> 0.1 }
      box { <-0.04,0,-1> <0.04,0.11,1> }
    difference {
      cylinder { <0,0,-0.14> <0,0,0.14> 0.24 }
      cylinder { <0,0,-1> <0,0,1> 0.15 }
      torus { 0.24,0.04 rotate <90,0,0> translate <0,0,-0.14> }
      torus { 0.24,0.04 rotate <90,0,0> translate <0,0,0.14> }
    // Dents
    #declare Rotation = 360 ;
    #while ( Rotation > 0 )
      difference {
        intersection {
          cylinder { <0,0,-0.3> <0,0,0.3> 0.15 translate
<-0.11,0.46,0> }
          cylinder { <0,0,-0.3> <0,0,0.3> 0.15 translate <0.11,0.46,0> }
          cylinder { <0,0,-0.2> <0,0,0.2> 0.54 }
        cylinder { <0,0,-1> <0,0,1> 0.48 }
        rotate <0,0,Rotation>
      #declare Rotation = Rotation - 12 ;
  texture { // your texture here.. mine's no good... :)
    pigment { color Gold }
    normal { bumps 0.2 scale 0.2 }
    finish { metallic reflection 0.05 }
// End copy
Download 'gear.jpg' (26 KB)
Preview of image 'gear.jpg'
