POV-Ray : Newsgroups : povray.binaries.images : Cartoon experiments Server Time
14 May 2026 05:00:26 EDT (-0400)
  Cartoon experiments (Message 1 to 9 of 9)
Subject: Cartoon experiments
Date: 16 Oct 2002 08:29:03
Message: <3dad5b8f$1@news.povray.org>
I've been playing around with using povray to make cartoons out of objects.
It only goes so far in showing one a "pencil thin outline" of a character.
Any pointers on improving this, or have I reached the theoretical limit?
BTW using specular in the finish will inevitably force your character to
have a color of   rgb <a,b,c>
where a,b,c are either 0 or 1.....
#declare diff2= blob{
        ......//dozens of elements
        texture{pigment{rgb <0.8,.3,.1>}  finish{ phong 1 phong_size 0 }
#declare bodyLight = light_source {<0,0,0> rgb <.9,.5,0.2>}
light_group {
  light_source {bodyLight}
  object {diff2 translate 25*z+scene_location}
  global_lights off
Download 'cart08.JPG' (10 KB)
Preview of image 'cart08.JPG'
Subject: Re: Cartoon experiments
Date: 16 Oct 2002 16:21:03
Message: <3DADCA36.7F4E6362@hotmail.com>
> objects.  It only goes so far in showing one a "pencil thin outline"
> of a character. Any pointers on improving this, or have I reached the
> theoretical limit?
You could probably do this:
Render three versions of each image, one with only the red, one with
only the green, and one with only the blue (use the Define command
line switch to control the render).
Take the resulting three images, and base a pigment_pattern on each
one.  Combine the results.  This enables you to set varying levels
of discrete color.
Another trick you would try would be to define where you camera is,
then develop a macro which takes the specs for a primitive and builds
an outline around it; you will need to know the camera specs in order
to correctly position the outline object.
John
Date: 16 Oct 2002 22:52:38
Message: <3dae25f6$1@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:3DADCA36.7F4E6362@hotmail.com...
> of discrete color.
This paragraph spawned an idea of simply using slope!
 pigment {  slope {-z }
        pigment_map{
        [0.65 rgb 0]
        [0.65 rgb <.9,.5,0.2>]
finish{diffuse 0 ambient 1}}
Download 'cartb10.jpg' (11 KB)
Preview of image 'cartb10.jpg'
Date: 16 Oct 2002 23:54:03
Message: <3dae345b@news.povray.org>
You might want to check out the stuff posted end of april beginning of may
this year. I'm not sure about links to the posts but there was a lot of
subsuquent postings of cell shading techniques, you might want to take a
look at them.
anyway, have fun
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg",r,1))-97;
disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4pigment{rgb 10}}_(r+1)
#end#end _(1)//KL
Date: 17 Oct 2002 08:19:28
Message: <3daeaad0$1@news.povray.org>
Thanks for the pointer.  I saw some nice work, but  AFAICS, they all
involved either patches or MegaPov post-processing or orthographic cameras.
But my newsreader may not have been showing me all the posts.   Did someone
post a technique that wasn't simply the slope pigment?
"Kevin Loney" <klo### [at] pt2mcom> wrote in message
news:3dae345b@news.povray.org...
> april beginning of may this year.
Date: 17 Oct 2002 10:15:52
Message: <3DAEC5E2.37A58714@onwijs.com>
>         pigment_map{
>         [0.65 rgb 0]
Good trick! But wouldn't that only work on rounded objects?
Remco
Date: 17 Oct 2002 10:33:43
Message: <3daeca47@news.povray.org>
actually, there is a way to use the slope pattern, and a perspective camera,
I haven't tried the technique yet, but the post was entitled galactic
apples.
Kevin
#end#end _(1)//KL
Date: 17 Oct 2002 13:04:36
Message: <3daeeda4@news.povray.org>
"Remco de Korte" <rem### [at] onwijscom> wrote in message
news:3DAEC5E2.37A58714@onwijs.com...
Well, perhaps one would have to put the person in a scene with rounded
scenery...
Download 'gregbox2.JPG' (37 KB)
Preview of image 'gregbox2.JPG'
Date: 17 Oct 2002 13:47:48
Message: <3daef7c4@news.povray.org>
news:3daeca47@news.povray.org...
camera,
> apples.
The only problem with using the slope pattern is it doesn't work properly
for sharp edges (eg. boxes) but only for smooth shapes.
-tgq
