POV-Ray : Newsgroups : povray.binaries.images : ISO CGS issue Server Time
13 Sep 2025 22:03:54 EDT (-0400)
  ISO CGS issue (Message 1 to 3 of 3)
Subject: ISO CGS issue
Date: 14 Oct 2002 05:22:49
Message: <3daa8ce9@news.povray.org>
I'm still working on my jellyfish model, first part is convert in ISO CGS
and work fine - at least the way I want -
See attached image.
But I am in trouble using IC_Merge_Array. The code I try is:
#declare SP4 = IC_Translate ( IC_Scale ( IC_Sphere ( <0, 0, 0 > , 1 ), < 0.5
, 1 , 0.2 > ), < 0.7 , -0.7 , 0 > )
#declare SP_Array = array[12]
#declare SP_Array[0] = SP4
#declare SP_Array[1] = IC_Rotate( SP4 , y*30 )
#declare SP_Array[2] = IC_Rotate( SP4 , y*30 )
#declare SP_Array[3] = IC_Rotate( SP4 , y*60 )
#declare SP_Array[4] = IC_Rotate( SP4 , y*90 )
#declare SP_Array[5] = IC_Rotate( SP4 , y*120 )
#declare SP_Array[6] = IC_Rotate( SP4 , y*150 )
#declare SP_Array[7] = IC_Rotate( SP4 , y*180 )
#declare SP_Array[8] = IC_Rotate( SP4 , y*210 )
#declare SP_Array[9] = IC_Rotate( SP4 , y*240 )
#declare SP_Array[10] = IC_Rotate( SP4 , y*270 )
#declare SP_Array[11] = IC_Rotate( SP4 , y*300 )
#declare MedTent = IC_Merge_Array ( SP_Array )
but I get the following message:
File: D:\transfert\perso\povfile\include\iso_csg.inc  Line: 82
        #if (Counter>0) , #end
          _ICSG_Array[Counter] <----ERROR
Parse Error: Attempt to access uninitialized array element.
and Christoph Hormann code is:
#macro IC_Merge_Array(_ICSG_Array)        // merge an array of objects
  #local Size=dimension_size(_ICSG_Array,1);
  function {
    min(
      #local Counter=0;
      #while (Counter<Size)
          _ICSG_Array[Counter] (x,y,z)  // line 82
        #local Counter=Counter+1;
Any clue to solve this?
Chaps.
Download 'meduse2.jpg' (22 KB)
Preview of image 'meduse2.jpg'
Subject: Re: ISO CGS issue
Date: 14 Oct 2002 05:34:25
Message: <3DAA8FA1.FF0EA924@gmx.de>
This does not work, SP4 is a function.  Try:
#declare SP_Array[0] = function { SP4(x, y, z) }
Date: 14 Oct 2002 05:57:28
Message: <3daa9508@news.povray.org>
Fast response time :o)
Many thanks, Christoph,
it works - even if it is a bit slow :o[
Thank you for posting all this work.
Chaps.
news:3DAA8FA1.FF0EA924@gmx.de...
0.5
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
