POV-Ray : Newsgroups : povray.binaries.images : Help! (11Kb Attachment) Server Time
25 Mar 2026 06:44:56 EDT (-0400)
  Help! (11Kb Attachment) (Message 1 to 8 of 8)
Subject: Help! (11Kb Attachment)
Date: 21 Sep 2002 12:58:12
Message: <3d8ca524@news.povray.org>
Folks:
Help!
Why is the color of the sphere lighter under water than it is
above water?  Is there any way that I can fix this?
Aaron
Aaron Gillies
New York City
x3rxes[^]yahoo.com
Download 'water.JPG' (11 KB)
Preview of image 'water.JPG'
Subject: Re: Help! (11Kb Attachment)
Date: 21 Sep 2002 13:54:06
Message: <3d8cb23e$1@news.povray.org>
Source perhaps?
 - Slime
[ http://www.slimeland.com/ ]
Date: 21 Sep 2002 14:09:43
Message: <3d8cb5e7$1@news.povray.org>
"Slime" <slm### [at] slimelandcom> wrote in message news:3d8cb23e$1@news.povray.org...
> Source perhaps?
It's nothing exotic ... just basic stuff:
  location <0, 0, -30>
  look_at <0, 0, 0>
  rotate <5, 0, 0>
light_source {
  <-10000, 10000, -10000>
  rgb 2
// Sky
background {
  color rgb <.25, .5, 1>
// Water
plane {
  y, 0
    pigment { color rgb 1 filter 1 }
    finish { reflection { 0, 1 } }
    normal { bozo 2 }
// Ocean Floor
plane {
  y, -1000
  texture { pigment { color rgb .25 } }
// Sphere
sphere {
  0, 10
  texture { pigment { color rgb .5 } }
Aaron
Aaron Gillies
New York City
x3rxes[*]yahoo.com
Date: 21 Sep 2002 14:15:00
Message: <3D8CB723.44C8981@gmx.de>
Adding 'conserve_energy' to your water finish probably helps.
Date: 21 Sep 2002 14:17:39
Message: <3d8cb7c3$1@news.povray.org>
Erm, yes ...
That pretty much fixed it. :)
Thanks.
Aaron
Aaron Gillies
New York City
x3rxes[*]yahoo.com
Date: 21 Sep 2002 16:55:35
Message: <3d8cdcc7@news.povray.org>
Mathematically, what does this keyword do?
 - Slime
Date: 21 Sep 2002 17:13:07
Message: <3D8CE0E3.26DCE9D7@gmx.de>
Date: 21 Sep 2002 20:00:00
Message: <3d8d0800$1@news.povray.org>
> See Docs: '6.7.3.5 Conserve Energy for Reflection'
It says...
"When conserve_energy is enabled, POV-Ray will multiply the amount filtered
and transmitted by what is left over from reflection (for example, if
reflection is 80%, filter/transmit will be multiplied by 20%)."
So what does it mean when "reflection is 80%"? When does that occur? Is it
talking about "when variable reflection causes only 80% of the maximum
reflection to occur", or "when you use reflection .8", or "when the color of
the light reflected is <.8,.8,.8>?" Or what?
AFAIK, reflection can't be measured in percentages; it's merely the color of
the light coming from the reflected direction multiplied by some value, and
added onto the color of the object at that point. The color of the incoming
light could be any value from negative to positive infinity. I see no way to
represent that as a percentage.
So, basically, here's how I believe reflection and transmittance is normally
calculated:
color_of_object_at_point_a =
color_caused_by_pigment_of_object_and_light_sources_at_point_a
incoming_light_at_reflected_angle * reflection_amount_at_point_a
incoming_transmitted_light * transmission_amount_at_point_a
Am I right or wrong? If I'm right, how is this equation modified to take
conserve_energy into account?
 - Slime
