POV-Ray : Newsgroups : povray.binaries.images : Portrait of Autumn (3000 oak leaves v.2) Server Time
25 Jun 2026 08:38:51 EDT (-0400)
  Portrait of Autumn (3000 oak leaves v.2) (Message 11 to 12 of 12)
Subject: Re: Portrait of Autumn (3000 oak leaves v.2)
Date: 14 Sep 2002 02:14:08
Message: <3d82d3b0@news.povray.org>
Jim Kress wrote:
> The leaves being one sided meshes, it shouldn't be too hard to add a degree
> of randomness to their exterior outline (use the random number generator).
> The lobes in the leaves should be of varying sizes as well.
You missed my point. The reason I *can* have so many leaves is because
meshes can be reused very efficiently. I don't know of any way to vary
the shape of the mesh once it's created except by disproportional
scaling, and I couldn't possibly afford to use several different meshes
as the scene is approaching the limits of my RAM as-is.
I recall back when people were playing with grass meshes that there was
some trick to vary the shape of the mesh after its creation (in order to
make it fit the terrain), but I never understood how it was done, and I
think all the sample code assumed a flat plain. :(
> As to the size of the leaves, given the scale defined by the sidewalk
> segments, the leaves are too small.  Indeed, if we assume the sidewalk is 3
> feet wide, the leaves are 0.95 inches long.
The sidewalk *is* 3 feet wide; good (or lucky) guess. The random scaling
code should be producing leaves about 2 to 3 inches long (which is how
long they appear around here; different species perhaps). I never
checked against the sidewalk to see if it was so, since they didn't
appear radically out of scale, but I will recheck that part.
> You could keep some as small as they currently are, but the others should be
> larger.  In addition, the larger leaves should be slightly curled at the
> edge but flatter in the middle.
That at least should be easy to accomplish; the mesh has some curling
and warping at the edges already, so flattening the smaller leaves would
reduce the effect.
Thanks for the feedback, BTW. It's very helpful, or at least it will be
when I get around to implementing it in a couple days.
-Xplo
Date: 14 Sep 2002 02:34:49
Message: <3d82d889@news.povray.org>
My pleasure.  I don't usually get this detailed with feedback, but I think
your project has a lot of potential so I went wild.
Jim
