POV-Ray : Newsgroups : povray.binaries.images : Two torii: parametric texture problem? Server Time
24 Jun 2026 04:51:27 EDT (-0400)
  Two torii: parametric texture problem? (Message 1 to 7 of 7)
Subject: Two torii: parametric texture problem?
Date: 10 Sep 2002 14:07:36
Message: <3d7e34e8$1@news.povray.org>
light_source{<0,100,-50> color rgb 10}
background{blue 1}
#declare r0=2;
#declare r1=1;
#declare AMBIENT_VARIABLE=0;
#while(AMBIENT_VARIABLE<1.1)
parametric {
   function { cos(u)*(r0+r1*cos(v)) }
   function { sin(u)*(r0+r1*cos(v)) }
   function { r1*sin(v) }
   <0,0>, <2*pi,pi>
   contained_by { sphere{0, 4.1} }
   max_gradient .14
   accuracy 0.001  //  0.0001
   precompute 10 x,y,z
   texture{pigment {rgb 1}
   finish{ambient AMBIENT_VARIABLE}
   translate 12*z+x*(-4+8*AMBIENT_VARIABLE)
#declare AMBIENT_VARIABLE=AMBIENT_VARIABLE+1;
Download 'torri.JPG' (5 KB)
Preview of image 'torri.JPG'
Subject: Re: Two torii: parametric texture problem?
Date: 10 Sep 2002 14:47:26
Message: <3d7e3e3e@news.povray.org>
The only strangeness I see is that the black torus shouldn't be completely
black, since there's a light source, and its diffuse isn't set to zero.
Otherwise, everything looks correct.
But I don't know what direction we're looking at it from, since you haven't
included the whole scene.
In the future, you should mention what the problem *is*... or did you do
that in a different group somewhere?
 - Slime
[ http://www.slimeland.com/ ]
Date: 10 Sep 2002 15:02:18
Message: <3d7e41ba$1@news.povray.org>
I thought it was a texture problem, where diffuse==0.
The whole scene file is included.
Date: 10 Sep 2002 17:04:49
Message: <3d7e5e71@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> wrote in message
news:3d7e41ba$1@news.povray.org...
Camera is default, unused in script. Yes, that would seem to be so, the
diffuse isn't right or even the black torus would be white with a light
source color of 10.
Ah, now that I've rendered it I see it works okay here. I get a lit and
shadowed object on left side. I don't know what is wrong with that then.
Date: 10 Sep 2002 21:10:03
Message: <web.3d7e97d1f560142f37dc5dec0@news.povray.org>
> okay here. I get a lit and shadowed object
> with that then.
With two different PC's I get the left torus to be black.  Could you post
what you see?
Subject: Re: Two torii: nothing wrong here
Date: 10 Sep 2002 23:26:57
Message: <3d7eb801@news.povray.org>
Here it is, small but obvious enough. Only thing I had changed from the
first time I tried rendering is the light source color is only 1 instead of
10.
Farewell,
Download '00.jpg' (4 KB)
Preview of image '00.jpg'
Date: 11 Sep 2002 05:40:20
Message: <l73unus326ambu0o4ct8ihpdasrefqr917@4ax.com>
On Tue, 10 Sep 2002 14:06:38 -0400, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
There can be some bug in parametric code. Try change container to:
   contained_by { box{-4.1 4.1} }
in your scene. The image looks different. Left object is now partially white.
I have partially pointed what can cause bugs in parametric object in
http://news.povray.org/saqrmuoi41v5iqkclmmggtk06n8t32s789%404ax.com
Read also thread http://news.povray.org/povray.general/26669/ .
BTW: Looking at your script I have a note. Do you one you waste memory a lot ?
IIRC parametric object is internally optimized to share precomputed data
between instances. So you can save memory changing your object definition this
way:
#declare Parametric_Example=parametric {
   <0,0>, <2*pi,pi>
   max_gradient .14
   precompute 10 x,y,z
  object {
    Parametric_Example
    texture{
      pigment {rgb 1}
ABX
