POV-Ray : Newsgroups : povray.binaries.images : Geodesic Dome Server Time
26 Aug 2025 22:56:12 EDT (-0400)
  Geodesic Dome (Message 1 to 8 of 8)
Subject: Geodesic Dome
Date: 7 Sep 2002 22:59:26
Message: <3d7abd0e@news.povray.org>
Hi all.
I want to do a Geodesic Dome, so I have searched the net for the formulas.
All I've found was a bunch of mathmatical formulas I don't understand and in
one site I've found a pre-made GeoDome with the coords of the vertices. (see
GeodesicDomeTest1.jpg)
But since this wasn't enough for what I wanted, I've wrote a macro to sub
divide the triangles, and this is the result.:
GeodesicDomeTest2.jpg  --> 1 subdivision
GeodesicDomeTest3.jpg  --> 2 subdivisions
GeodesicDomeTest4.jpg  --> 3 subdivisions
Todo next:  wireframe to go with the vertices
Best regards
Download 'GeodesicDomeTest1.jpg' (65 KB) Download 'GeodesicDomeTest2.jpg' (43 KB) Download 'GeodesicDomeTest3.jpg' (59 KB) Download 'GeodesicDomeTest4.jpg' (69 KB)
Preview of image 'GeodesicDomeTest1.jpg'
Preview of image 'GeodesicDomeTest2.jpg'
Preview of image 'GeodesicDomeTest3.jpg'
Preview of image 'GeodesicDomeTest4.jpg'
Subject: Re: Geodesic Dome
Date: 8 Sep 2002 08:32:54
Message: <3D7B43B9.83EE483A@pandora.be>
JPGargoyle wrote:
> Hi all.
I suppose you didn't see Uwe Zimmermann's 1999 include file geodesic.inc
that also defines macros to determine a geodesic division on a sphere.
That's a lot more than "a pre-made geodome with the coords of the
vertices".
If possible: I'm interested in your macros.
> Best regards
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Date: 8 Sep 2002 11:12:53
Message: <3d7b68f5@news.povray.org>
I have his macro and it works, but it doesn't output a mesh2 or something
that can easily be converted to mesh2. This nags me.
I like your subdivision however. It gives a nice shape. Do you think your
macro could be used to subdivide any array of points?
Hugo
Date: 8 Sep 2002 12:48:03
Message: <3d7b7f43$1@news.povray.org>
> vertices".
Nope. I havn't heard of it until now, but I'm interested in taking a look at
it.
Can you please tell me where I can take a look at it? Thanks.
I have posted the sources at povray.binaries.scene-files. :)
Please notice that it wasn't made with the possibility of being posted so it
is not optimized and might be confusing because my approach isn' the best at
all. Its just a test in its early stages of development.
But if you neet to ask something feel to do it.
Best regards.
Date: 8 Sep 2002 12:54:49
Message: <3d7b80d9$1@news.povray.org>
hmmm. They will have to be arranged in sets of three, because it is made to
subdivide triangles.
You probably will have to modify it a lot because it doesn't take into
consideration any normals information.
And I think it just works this fine on this example becauseall the triangles
sub-divided have the 3 sides with almost the same length, but you can try it
with trinagles with different proportions (I havn't tryed it yet)
The points here appear at the surface of the sphere because the sphere is
centered at the origin and I translate the point into a distance from the
center of the sphere equal to the radius of the sphere (in this case 1).
Best regards.
Date: 9 Sep 2002 02:27:32
Message: <3D7C3F9A.843C856D@pandora.be>
A search on the povray site resulted in
http://www.geocities.com/SiliconValley/Lakes/5432/povray/geodesic.html
> > vertices".
> it.
> Best regards.
Herman Serras
Gent (Belgium)
Date: 9 Sep 2002 07:35:03
Message: <web.3d7c86c0c6ede976641f1e9f0@news.povray.org>
Thanks a lot. :)
Best regards.
Date: 12 Sep 2002 13:45:09
Message: <web.3d80d15bc6ede976717ea7a0@news.povray.org>
Here is a quick and dirty geodome I developed. The easiest code to get the
shape, I think. Dirty, because spheres and cylinders are drawn several
times. This is because the algorithm was developed to create a mesh and not
a wireframe model.
I don't know the exact definition of a geodesic dome, but all I heard about
it my shape seems to be one: the algorithm starts with an octahedron with 6
points and 8 triangles. Every triangle is recursively divided into four new
ones and each new point is projected onto the surface of the sphere.
So can anybody tell me if this is one?
//basic values
#declare node_rad=0.1;
#declare link_rad=0.04;
#declare dome_rad=3;
#declare dome_rec_depth=3;
//recursive geodesic triangle subdivision
#macro tri1(a,b,c,depth)
    #if (depth < dome_rec_depth)
        #local ab= vnormalize(a+b)*dome_rad;
        #local bc= vnormalize(b+c)*dome_rad;
        #local ca= vnormalize(c+a)*dome_rad;
        tri1(bc,ca,ab,depth+1)
        tri1(a,ab,ca,depth+1)
        tri1(ab,b,bc,depth+1)
        tri1(ca,bc,c,depth+1)
    #else
        sphere{a, node_rad}
        sphere{c, node_rad}
        cylinder{a,b,link_rad}
        cylinder{b,c,link_rad}
        cylinder{c,a,link_rad}
//declare corners of octahedron
#declare v1=-x * dome_rad;
#declare v2=-y * dome_rad;
#declare v3= x * dome_rad;
#declare v4= y * dome_rad;
#declare v5= z * dome_rad;
#declare v6=-z * dome_rad;
//draw scene
camera{location < 5,6,-3> look_at < 0,0,0>}
light_source {< -90,140,-190>  color rgb 1}
union{
    tri1(v1,v2,v5,0)
    tri1(v2,v3,v5,0)
    tri1(v3,v4,v5,0)
    tri1(v4,v1,v5,0)
    tri1(v1,v2,v6,0)
    tri1(v2,v3,v6,0)
    tri1(v3,v4,v6,0)
    tri1(v4,v1,v6,0)
    pigment{color rgb < 1,0.8,0.5>}
    finish{specular 1}
