POV-Ray : Newsgroups : povray.binaries.images : Odd blur effect: squared spheres Server Time
12 Jan 2026 02:46:47 EST (-0500)
  Odd blur effect: squared spheres (Message 1 to 10 of 25)
Subject: Odd blur effect: squared spheres
Date: 27 Aug 2002 05:57:31
Message: <3d6b4d0b@news.povray.org>
Currently I am rendering a large version of a dice image. The dice points
really get angularly. Does anyone know why?
Thanx,
Rene
Rene Schwietzke
r.schwietzke<at>reneschwietzke.de
Download 'blur.jpg' (24 KB)
Preview of image 'blur.jpg'
Subject: Re: Odd blur effect: squared spheres
Date: 27 Aug 2002 06:50:40
Message: <3D6B59A8.3070709@free.fr>
Rene Schwietzke wrote:
> Hi,
Dive in the source code (unless it is documented ?),
the blur code as some magic values on blur_sample IIRC which
use an hexagonal grid instead of square grid. At least, it was
in 3.1 ...
Other solution might be to increase the blur_sample,
or reduce the variance or increase the confidence.
 Go read section 6.4.3 of the help (pov 3.5)
Date: 27 Aug 2002 08:29:14
Message: <3d6b709a@news.povray.org>
I found three constants in the help about Hex_Blur, might be related but the
camera SDL does not allow any additional settings.
Hex_Blur1 = 7
Hex_Blur2 = 19
Hex_Blur3 = 37
My settings are:
blur_samples 150
variance 0
confidence 0.9999999
Any ideas? Your assumption seems to be right...
Rene
"Le Forgeron" <jgr### [at] freefr> wrote in message
news:3D6### [at] freefr...
> in 3.1 ...
Date: 27 Aug 2002 12:37:32
Message: <3d6baacc@news.povray.org>
AFAIK the focal blur is achieved by scattering the camera location
point in a rectangular area, while maintaining the focal point the
same. The size of this area is determined by the aperature keyword.
Date: 27 Aug 2002 13:30:22
Message: <3d6bb72e@news.povray.org>
Shouldn't it be a circular area for realism?
 - Slime
[ http://www.slimeland.com/ ]
Date: 27 Aug 2002 14:05:30
Message: <3d6bbf6a$1@news.povray.org>
"Slime" <slm### [at] slimelandcom>
correct ...
either that or you can start modelling complex shapes for a
probability model. Meaning, you support a greyscale bitmap
where black says "no here won't get a ray shooten from" and
white means that from here will get a ray shooten with the
highest probability.
This would allow you to form flare shapes as they sometimes
appear in photography; think of hexagonal or triangular ones.
The problem would be, that it will even slower to determine
the point.
Date: 27 Aug 2002 15:10:37
Message: <3d6bcead@news.povray.org>
news: 3d6b4d0b@news.povray.org...
See this page
http://www.kenrockwell.com/tech/bokeh.htm
There's a patch that implements this in POV-Ray that is currently being
ported to 3.5 (it's under testing and not available yet). From what I heard
it's faster that the regular focal_blur but I have not verified this myself.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 27 Aug 2002 15:24:54
Message: <3d6bd206$1@news.povray.org>
> correct ...
I don't think that's correct actually...
> the point.
True, but I would be happy with the possibility to choose between a circular
area and an area in the shape of a regular polygon.
I was trying to do focalblur by averaging different renders earlier this day.  I
came up with the following formula to scatter points inside a regular polygon:
  #declare Seed=seed(whatever);
  #declare angles=<insert number of angles here>;
  #declare Rot=360*rand(Seed);
  #declare X=pow(rand(Seed),.5);
  #declare Rot2=Rot/(360/angles);
  #declare fraqrot=Rot2-int(Rot2);
  #declare fraqrot2=abs(fraqrot-.5);
  #declare fraqrot3=pow(fraqrot2*2,.5);
  #declare Location=vrotate(x*X*(.8+.2*fraqrot3),Rot*z);
This produces a random point within a regular polygon inside a circle with
radius 1 (I think, could be that it's a bit outside that circle...) (more or
less, it's not a perfect polygon, and it needs more than 3 angles to look like a
polygon)
cu!
Date: 27 Aug 2002 16:06:48
Message: <3d6bdbd8@news.povray.org>
probably right....
but please compare these lines to the simple way of determing a single point
in an rectangle concerning the time it takes to compute it ...
... and then take into account, that this has to been done multiple times
per pixel ... Maybe its ok to precompute ~2^10 such values and store them
in a table, so you can reuse them later ... but I'm not sure this will help
Date: 27 Aug 2002 16:17:34
Message: <3d6bde5e@news.povray.org>
day.  I
polygon:
> probably right....
Yes, a rectangle, or a circle, will be faster, that's why you should have the
option to use a circle (or a rectangle, but I don't think that would give
realistic results actually).
cu!
