Please ignore the pixel-art from the image map used for the clothing... same
woman as previous post with jewelry composed from POV primatives.
Does she look lonelier this close?
Robert J Becraft
aka cas### [at] aolcom
Download 'Lonely3T.jpg' (86 KB)
Preview of image 'Lonely3T.jpg'
I really don't know if she looks "lonely", but for sure
not very happy. I even think it is impossible to create
a facial expression for lonelyness.
Anyway, I like this closeup with the jewelry very much.
Just one idea: make the eyelashes of "Posette" look
more real.
You can render this with POV-Ray quite easy either
by composing the image map (the body texture) together
with a transparency map for the lashes used as alpha
channel (done with any image processing software) or
even better by using "pigment_pattern".
With pigment_pattern you can even create realistic
looking lashes and hair with specular reflection - but
without that faked (painted) specular highlights as it is
the case with the transmapped poser hair.
so long
-Ive
Gawd I hate Poser. Poser 5 had better do a better job
with the eyes...
Tim Cook
Version: 3.12
"Robert J Becraft" <cas### [at] aolcom> wrote in
news:3d545c51@news.povray.org
> clothing... same woman as previous post with jewelry composed from POV
> primatives.
yes, she looks lonely, because - she looks like a last person alive from...
Wolfensein 3D ;-)) do something with this pixelized textures :)
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3D5### [at] scifi-fantasycom...
> with the eyes...
...hmm, thats a little like saying: "I hate POV-Ray.
POV 3.5 should better do a better job with reflecting
spheres". It's always a question what YOU are doing
with the tools you use.
BTW Poser is still v.4 and you can easily render a Poser
figure with very realistic eyes, even with POV-Ray :-)
so long
-Ive
"Ive" <ive### [at] lilysoftcom> wrote in message news:3d546c8f@news.povray.org...
> more real.
?? How do you suggest I do this? Output from obj2pov below...
#declare OBJuvPOV_Texture = texture
pigment
image_map
png "../../poser/OBJuvPOV.png"
#declare OBJuvPOV_Texture_OBJuvPOVskin = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVnipples = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVlips = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVeyeBrows = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVinnerMouth = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVtongue = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVteeth = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVlashes = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVpupils = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOViris = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVeyeBall = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVfingerNails = texture {pigment{color
Scarlet}}
#declare OBJuvPOV_Texture_OBJuvPOVtoeNails = texture {OBJuvPOV_Texture}
> so long
> -Ive
I've never seen a Poser 4 figure with anything but open
eyes that even pretended to look realistic. And I know
it's still version 4, I was commenting that they need to
fix the way the eye morphs are done for version 5.
Tim Cook
Version: 3.12
>> more real.
There's info on how to convert Poser transparency maps into something
that can be used in POV in my "Poser to Pov" tutorial. Particularly
section 4 "Poser 4 and Transparency Maps".
<http://www.econym.demon.co.uk/posetut/>
Mike Williams
Gentleman of Leisure
O.K. I read the tutorial...sorta makes sense. So to do what Iva said, I'd
modify the OBJUVPOV.png file adjusting the alpha channel for the eyelashes
to only trace the lashes themselves?
??? Correct? Can PSP V3 do that? I have a really old version of PSP.
"Mike Williams" <mik### [at] econymdemoncouk> wrote in message
news:XkF### [at] econymdemoncouk...
> >> more real.
> Mike Williams
It would probably be easier to obtain a copy of "translash.jpg" from
DigitalBabes <http://digitalbabes2.com/>, which contains a suitable
transparency map for the eyelashes of the P4 female model. Scale it to
the same size as the texture map you're using as OBJUVPOV.png and load
it into its alpha channel.
All it needs to be able to do is handle PNG alpha channels. I don't have
a version of PSP that old, so I can't check.
While you're at it, it wouldn't hurt to use one of the DigitalBabes hair
pieces that come with transparency maps. They're an awful lot more
realistic than the hair that comes with P4.
Mike Williams
