POV-Ray : Newsgroups : povray.binaries.images : Loneliness WIP, Closeup Server Time
17 Jul 2026 22:25:31 EDT (-0400)
  Loneliness WIP, Closeup (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Loneliness WIP, Closeup
Date: 10 Aug 2002 15:22:06
Message: <XkFOkIAGZWV9EwkO@econym.demon.co.uk>
Wasn't it Robert J Becraft who wrote:
>"Ive" <ive### [at] lilysoftcom> wrote in message news:3d546c8f@news.povray.org...
>> > Does she look lonelier this close?
>> I really don't know if she looks "lonely", but for sure
>> not very happy. I even think it is impossible to create
>> a facial expression for lonelyness.
>> Anyway, I like this closeup with the jewelry very much.
>> Just one idea: make the eyelashes of "Posette"  look
>> more real.
>> You can render this with POV-Ray quite easy either
>> by composing the image map (the body texture) together
>> with a transparency map for the lashes used as alpha
>> channel  (done with any image processing software) or
>> even better by using  "pigment_pattern".
>?? How do you suggest I do this?  Output from obj2pov below...
There's info on how to convert Poser transparency maps into something
that can be used in POV in my "Poser to Pov" tutorial. Particularly
section 4 "Poser 4 and Transparency Maps".
<http://www.econym.demon.co.uk/posetut/>
Mike Williams
Gentleman of Leisure
Date: 10 Aug 2002 16:10:57
Message: <3d557351@news.povray.org>
O.K.  I read the tutorial...sorta makes sense.  So to do what Iva said, I'd
modify the OBJUVPOV.png file adjusting the alpha channel for the eyelashes
to only trace the lashes themselves?
??? Correct?  Can PSP V3 do that?  I have a really old version of PSP.
"Mike Williams" <mik### [at] econymdemoncouk> wrote in message
news:XkF### [at] econymdemoncouk...
> >> more real.
> Mike Williams
Date: 10 Aug 2002 16:51:40
Message: <8VzUIFAdxXV9Ewz1@econym.demon.co.uk>
It would probably be easier to obtain a copy of "translash.jpg" from
DigitalBabes <http://digitalbabes2.com/>, which contains a suitable
transparency map for the eyelashes of the P4 female model. Scale it to
the same size as the texture map you're using as OBJUVPOV.png and load
it into its alpha channel.
All it needs to be able to do is handle PNG alpha channels. I don't have
a version of PSP that old, so I can't check.
While you're at it, it wouldn't hurt to use one of the DigitalBabes hair
pieces that come with transparency maps. They're an awful lot more
realistic than the hair that comes with P4.
Mike Williams
Date: 10 Aug 2002 17:12:33
Message: <3d5581c1$1@news.povray.org>
I'm using Poser 3... and assume same things apply below?
news:8Vz### [at] econymdemoncouk...
I'd
eyelashes
> Mike Williams
Date: 10 Aug 2002 18:17:03
Message: <3d5590df@news.povray.org>
the way Robert uses alpha channels is one
way to do it, but with POV 3.5 you can also use
pigment_pattern and this has some advantages:
1. You do not need to compose the texture map
together with the transparency map, so it's easier
to handle.
2. You can still use specular highlights, and that  is
impossible with the "alpha channel technique" 'cause
the highlights are also applied to the invisible parts.
Basicly this is the same technique I have used for
the grille in my Marshall top+speaker image.
Soon I will post a short tutorial to
povray.binaries.tutorials to make this more clear.
And anyway it's a good idea to visit DigitalBabes
for the translash.jpg image.
What poser figure do you use, I thought it is the
p4woman , but you do use Poser 3 ???
so long
-Ive
Date: 10 Aug 2002 18:27:48
Message: <3d559364@news.povray.org>
> Ive wrote:
> > BTW Poser is still v.4 and you can easily render a Poser
> > figure with very realistic eyes, even with POV-Ray :-)
> I've never seen a Poser 4 figure with anything but open
> eyes that even pretended to look realistic.  And I know
> it's still version 4, I was commenting that they need to
> fix the way the eye morphs are done for version 5.
..ahem, well you are right.
I have never tried to render a face close up with POV.
It is indeed not so easy to create realistic looking eyes
but I still think it is possible. See my face post in this ng.
so long
-Ive
P.S. sorry for the mail, I've pressed thewrong button.
Date: 10 Aug 2002 21:02:47
Message: <3d55b7b7@news.povray.org>
Poser 3 Nude Woman.
> so long
> -Ive
Date: 10 Aug 2002 21:44:17
Message: <zJEX$AAA$bV9EwyQ@econym.demon.co.uk>
Sorry. The P3 female has completely different geometry to the P4 female,
so the existing Poser transmaps won't fit. You will have to build your
own after all.
Once you've mastered transparency maps in POV, it might be worth taking
a look at the DigitalBabes hair. It doesn't look quite so good in Poser3
because that doesn't support transparency maps, and you'll have to
convert the texture from JPG to TIF, but it will look so much better in
POV (see the full-size rendering of the model in my tutorial for an
example).
>I'd
>eyelashes
>> Mike Williams
Mike Williams
Date: 10 Aug 2002 23:13:55
Message: <3d55d673@news.povray.org>
Yes, thats right, the Poser 3 Nude Woman does not work with the poser
4 eyelash transparency map. But it shouldn't  be so difficult to create one
and 'cause I think this would be useful for all Poser users I will create
one and post it to this ng when it's done.
But the other things I have done with the texture should also work with
the poser 3 figure so here are some ideas:
>#declare OBJuvPOV_Texture = texture
>   pigment
>        image_map
>            png "../../poser/OBJuvPOV.png"
>#declare OBJuvPOV_Texture_OBJuvPOVskin = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVnipples = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVlips = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVeyeBrows = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVinnerMouth = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVtongue = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVteeth = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVlashes = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVpupils = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOViris = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVeyeBall = texture {OBJuvPOV_Texture}
>#declare OBJuvPOV_Texture_OBJuvPOVfingerNails = texture {pigment{color
>Scarlet}}
>#declare OBJuvPOV_Texture_OBJuvPOVtoeNails = texture {OBJuvPOV_Texture}
well, thats fine, so you did use a converter with the uv-information intact.
I would change the textures declarations like:
#declare P_Body = pigment { image_map { png "../../poser/OBJuvPOV.png"
interpolate 2}}
#declare F_Body = finish { ambient 0 diffuse 0.6 specular 0.04 roughness
0.06 metallic}
and then do some variation like:
  pigment {P_Body}
  finish {F_Body}
  normal {granite 0.12 scale 0.02 }
I think for the P3 woman you have to scale the normals much smaller to
look good.
  pigment {P_Body}
   finish {diffuse 0.60 specular 0.33 roughness 0.015 metallic 0.5} // a
little glossy
   normal {granite 0.1 scale <0.045, 0.15, 0.045> }
  pigment {rgbt <0.1, 0.0, 0.4, 0.75> }  // apply the color for the lipstick
..and so on, maybe a small reflection for the fingernails and higher
specular values for the inner mouth.
I have also added variable reflection to the eyes, but as you can
see, they still do not look real.
... and finally the eyelashes:
#declare LashTrans = texture{   // the invisible part
      pigment {rgbft <0.008 , 0.005, 0.033, 0.0, 1.0> }
      finish {diffuse 0.56 specular 0.0}
#declare  LashText  = texture{  // the lashes
       finish {diffuse 0.56 specular 0.5 roughness 0.019 brilliance 1.5}
#declare LashPat = pigment {  // the trans map half sized to save memory
  image_map {png "/People/Brows&Lashes-2" interpolate 2}
  scale <0.5,1,1>   translate <0.5,0,0> // this scaling is only for
                                                           // the map I did
use to save some
                                                           // memory!!!
   pigment_pattern{LashPat}
   texture_map {
     [0.05 LashTrans ]    //  you can adjust these values to
     [0.85 LashText  ]    //  make the lashes look more or less thin
I have used the same technique also for the eye brows, so there
is only one map file for both, the brows and the lashes.
But this is not so important for the moment.
What you need now is a small transparency map that fits the p3woman.
You can search the web for something like this, try to do one by yourself
or wait 'till I have drawn one. (Maybe tomorrow.)
so long
-Ive
Date: 11 Aug 2002 00:10:15
Message: <3D55E3A6.8030601@scifi-fantasy.com>
It might be of interest to note that I hear tell they're
gonna be releasing Poser 5 later this year...I do hope
it requires less hacking just to make something look
decent than Poser 4...also it pisses me off these
websites that sell Poser models for $50 or more, just
for something that should be part of Poser already...:P
Tim Cook
Version: 3.12
