POV-Ray : Newsgroups : povray.binaries.images : find edges postprocess using functions Server Time
23 Apr 2026 01:38:12 EDT (-0400)
  find edges postprocess using functions (Message 1 to 5 of 5)
Subject: find edges postprocess using functions
Date: 24 Jul 2002 13:00:09
Message: <3d3edd19@news.povray.org>
Could someone please help me to delete the black lines at the image borders.
Source ist at p.t.s.f.
Simon
Download 'pp3.gif' (12 KB)
Preview of image 'pp3.gif'
Subject: Re: find edges postprocess using functions
Date: 24 Jul 2002 13:29:36
Message: <3d3ee400$1@news.povray.org>
Cool process!  I think I found a solution for you:
  #declare Ifun=
  function{
    pigment{
      image_map{
        png "pp2"
      warp{repeat y flip y} //<---add these two lines
      warp{repeat x flip x} //<-/
      translate -.5
      scale <image_width,image_height,1>*.5
this repeats the image in the function and flips it in the x and y
directions, that way there isn't any abrupt stop to the image used in the
function which is the problem you were having.  The function was creating an
edge at the edges of the image itself.  The image used in the function now
continues smoothly beyond the borders of your final scene, eliminating this
effect.
-tgq
Date: 24 Jul 2002 13:31:22
Message: <3d3ee46a@news.povray.org>
oops, the *0.5 isn't part of the solution, just used it for testing it out
and forgot to remove it.  Just add the two lines suggested.
-tgq
Date: 24 Jul 2002 14:25:12
Message: <3d3ef108@news.povray.org>
Thanks!
I think your solution will work for what I want to do. But I think it only
removes the edges at the edges caused by the distance(the red value) and not
the ones caused by different normals. Perhaps this would be visible when a
sphere or something like that is at the border of the image.
Date: 24 Jul 2002 14:27:53
Message: <chrishuff-C73DA6.13204524072002@netplex.aussie.org>
In article <3d3edd19@news.povray.org>, "Simon Adameit" <gom### [at] gmxde>
Too bad pattern functions only have access to the evaluation point, and
not the ray origin and direction, surface normal, etc. Of course, you
would still have to render the image several times to get all that
information into image files...but it would be useful in many other
cases. Interesting trick you used to get it from this scene...
