POV-Ray : Newsgroups : povray.binaries.images : The dark side of the trees (121 kbu) Server Time
18 Jul 2026 21:10:09 EDT (-0400)
  The dark side of the trees (121 kbu) (Message 51 to 60 of 66)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: The dark side of the trees (121 kbu)
Date: 23 Jul 2002 16:23:00
Message: <3D3DBA56.9000404@skynet.be>
Christopher James Huff wrote:
> raw_image filter restores the full float precision colors). Don't know
> of any workaround for 3.5 though, you would have to use an external
> program.
Wouldn't POV-Ray itself be able to read a 48 bits PNG ?
(you render in a 48 bits PNG, you use it as an image_map
  that fits exactly the screen, and you process it using
  eval_pigment and reconsturct the image with colored
  boxes)
Fabien.
Date: 23 Jul 2002 16:27:10
Message: <3d3dbc1e@news.povray.org>
In article <3d3c72af@news.povray.org> , "Gilles Tran" <tra### [at] inapginrafr>
wrote:
> They'll surely look better at the final full res of 6000*8000 which is
> rendering now.
What render time do you expect for it?  A week?
> - Regrets : the lighting. I had a lot of trouble with it, as the original
> image
> is not very gamma-tolerant : it looked ugly on low-gamma monitors and much
> too dark on others. I had to find a middle way so I tweaked the tones in
> post-process and some colors were lost (and there's some extra graininess
> too). I hope it looks right on your PC or Mac.
It looks good on Macs.
I have to say the image looks really, really great!!!  Nearly perfect,
except imho the shadow of the tree seems like it is a bit to far to the
left.  Maybe moving the shadow about ten pixels to the right would make it
look even better...
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Jul 2002 16:38:55
Message: <3d3dbedf@news.povray.org>
3d3dbc1e@news.povray.org...
About it. Less in fact, but I'll probably have to re-render little parts of
it with better radiosity settings and area_light settings.
> look even better...
Hmm, yes, you're right. I can still change it (still 60% to go on the large
render).
BTW, the main tree has its own light group with its own sun at a different
position that the main one, so that I could get both some direct light on
the trunk (from the light_group) and a highlight on the water (from the main
light)...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 23 Jul 2002 17:45:40
Message: <3d3dce84@news.povray.org>
> > program.
>   boxes)
> Fabien.
Isn't this a case of 'When all you have is a hammer everything starts to
look like a nail'? ;)
It sounds like a brilliant idea, still.
-Jide
Date: 23 Jul 2002 18:20:50
Message: <chrishuff-C53D0C.17133723072002@netplex.aussie.org>
In article <3D3### [at] skynetbe>,
>   boxes)
If you really want to do image processing of a large image in the POV
language...it will be very, very slow.
A better solution: use the image_map on a plane or box with ambient 1,
an orthographic camera and no light sources, and the curves post_process
filter. The raw_image filter won't be of any help here, since the data
has already been put through a PNG file. You will lose data for color
values >1, and will only get 16 bits per channel instead of the float
precision the post_process filters have access to...basically, MegaPOV
will be as limited as any other external program.
Date: 23 Jul 2002 19:01:22
Message: <4vnrju8p4dnopfhb4ckuc4narsdevjg2j5@4ax.com>
On Tue, 23 Jul 2002 22:19:34 +0200, Fabien Mosen
>  boxes)
I'd rather use a function pigment for that - much faster than parsing
a gazillion boxes.
Peter Popov ICQ : 15002700
Date: 23 Jul 2002 22:01:44
Message: <3d3e0a88$1@news.povray.org>
> a gazillion boxes.
To use boxes for postwork within Pov-Ray is exactly what I did in my last
two IRTC entries.
The method is awfully slow (compared with photoshop) and needs huge amounts
of memory
(a 1200*1600 render would need more than 1 GB !).
How can I use functions instead of pigments? I tried and failed so far.
Norbert
Date: 23 Jul 2002 22:03:59
Message: <chrishuff-E3E08F.20564823072002@netplex.aussie.org>
In article <4vnrju8p4dnopfhb4ckuc4narsdevjg2j5@4ax.com>,
> >  boxes)
> a gazillion boxes.
That's a good idea...you could do the same thing as the post_process
curves filter without needing the patch, though it would still have the
limitations of what you can put through a PNG file. A image_map pigment
function run through three spline functions and combined into the final
image with an average pigment would do the trick:
#declare imgFn = function {pigment {image_map {...}}}
#declare rCurveFn = function {spline {...}}
#declare gCurveFn = function {spline {...}}
#declare bCurveFn = function {spline {...}}
pigment {average
    pigment_map {
        [pigment {function {rCurveFn(imgFn(x, y, z).red).x}
            color_map {[0 rgb 0][1 rgb < 3, 0, 0>]}}]
        [pigment {function {gCurveFn(imgFn(x, y, z).green).x}
            color_map {[0 rgb 0][1 rgb < 0, 3, 0>]}}]
        [pigment {function {bCurveFn(imgFn(x, y, z).blue).x}
            color_map {[0 rgb 0][1 rgb < 0, 0, 3>]}}]
I used three splines here to make it easier to adjust each channel
separately, since splines use vectors you should be able to use just one
spline. You could also do things like use a spline value to scale the
color according to the brightness of the color.
Date: 24 Jul 2002 02:51:51
Message: <6gjsjuom2mlrciehrb4kd0kqhmm33d36nh@4ax.com>
On Mon, 22 Jul 2002 23:05:20 +0200, "Gilles Tran" <tra### [at] inapginrafr> wrote:
> - Rendered with povray 3.5
Respect!
ABX
Date: 24 Jul 2002 15:35:14
Message: <3D3F0089.9020500@skynet.be>
What's the bit-depth limit ?
Fabien.
