POV-Ray : Newsgroups : povray.binaries.images : Glowing thick wire effect? Server Time
14 May 2026 21:46:32 EDT (-0400)
  Glowing thick wire effect? (Message 11 to 13 of 13)
Subject: Re: Glowing thick wire effect?
Date: 15 Jul 2002 23:32:51
Message: <3d3393e3@news.povray.org>
I think you're having to deal with environmental factors; which is to say,
it all depends on how the light source object is applied to the scene. The
background is paramount when transparency is involved. I changed some things
but basically everyone is right about using merge to remove inside surfaces
first and foremost. To get the glowing effect you must look through at least
the edges of a media object. If the object is directly between a background
and camera then the appearance is different than when not aligned.
Obviously, the main concern with this particular scene is how to go about
getting a brighter interior and at the same time dimmer edges. I reduced the
transmit for one thing, that always tends to overbrighten the container
object if filter is used in conjunction.
Anyway, check out:
global_settings {
        radiosity {}
        photons {
                spacing .03
                media 100,2
#declare NixieColor = color rgbft<1.00,0.5,0.00,1,.5>;
#declare NixieColorEmit = color rgb<1.00,0.5,0.00>;
#declare NixieColorScat = color rgb<1.00,0.5,0.00>/5;
#declare Number1 =
merge {
   cylinder {<0,-0.95,0>,<0,0.95,0>,0.1}
   sphere {<0,-0.95,0>,0.1}
   sphere {<0, 0.95,0>,0.1}
 pigment {NixieColor}
 finish {ambient 0 diffuse 0}
   interior {
      media {
   emission NixieColor//Emit
     scattering { 4, NixieColorScat}
     density {rgb 2}
   intervals 1
   samples 20
   method 3
   hollow
   photons {target reflection on collect on}
#declare NixieNumber1 =
   light_source {
      0,
      NixieColor
      looks_like {Number1}
      area_light .1*x,y,2,6 jitter
      fade_distance 1
      fade_power 2
   photons {reflection on}
object{NixieNumber1 scale .25 translate <-1,-1,0>/3}
// things to see the light source and photons against
plane {z,1 pigment {rgb 1} hollow photons {target}}
box {-1,1 pigment {rgb 0} finish {reflection 1}
 photons {target reflection on}
  rotate <30,30,0>
   // rotate 15*y // add this to see number object on box
   translate <1.5,1,-.5>}
  location  <0, 0, -3>
  look_at   0
  angle 50
Date: 16 Jul 2002 04:46:04
Message: <3d33dd4c$1@news.povray.org>
> Well I thought about that but I also want the object
> to actually emit light too.
Emitting media works like ambient. It doesn't really emit light.
I was curious as to how it would look with pigments. I made an experiment:
//camera { location <-2,1,-3> look_at 0 }
//camera { orthographic location -3*z look_at 0 }
camera { location -3*z look_at 0 }
light_source { <-15,45,-60>,1 }
#declare Color1=<1, 1, .8 ,.9>;
#declare Color2=<1, 1, .5 ,.65>;
#declare Color3=<1.35, 1.35 ,1.35,0>;
#declare Cyl = cylinder { -1*y, 1*y, .15
 pigment { cylindrical pigment_map {
   [ 0 rgbt 1 ]
   [ .15 rgbt Color1 ]
   [ .39 rgbt Color2 ]
   [ 1 rgbt Color3 ] }
  scale <.135,1,1> }
 finish { ambient 1 diffuse 0 }
#declare Sph = sphere { 0, .15
 pigment { spherical pigment_map {
   [ 0 rgbt 1 ]
   [ .15 rgbt Color1 ]
   [ .39 rgbt Color2 ]
   [ 1 rgbt Color3 ] }
  scale <.135,.13,1> }
#declare Number0 = merge {
 #local cnt=0;
 #local step=.01;
 #while (cnt<1)
  object { Cyl scale <1,.04,1>
   translate .95*x rotate (cnt*360)*z }
  #local cnt=cnt+step;
 no_shadow
 bounded_by { box { <-1.3,1.3,.15>,<1.3,-1.3,-.15> }}
#declare Number1 = merge {
 object { Cyl scale <1,.95,1> pigment { turbulence .12 }}
 object { Sph translate -.95*y }
 object { Sph translate .95*y }
 no_shadow
object { Number0 translate -.5*x }
object { Number1 translate 1.2*x }
plane { z,10
 pigment { wrinkles
  pigment_map { [ 0 rgb .5 ] [ 1 rgb <1,.7,.6> ] }
  scale 4 }
 hollow
Date: 16 Jul 2002 08:59:52
Message: <3d3418c8$1@news.povray.org>
Yes!  That is what I'm trying to get to.  It looks like an element from
an electric stove top.  Great!
Thanks!
Patrick Dugan
"hughes b" <omn### [at] charternet> wrote in message
news:3d3393e3@news.povray.org...
things
surfaces
least
background
the
> Anyway, check out:
> global_settings {
>         radiosity {}
>         photons {
>                 spacing .03
>                 media 100,2
> #declare Number1 =
> merge {
>    interior {
>       media {
>      density {rgb 2}
>    intervals 1
>    samples 20
>    method 3
>    hollow
>    light_source {
>       0,
>       NixieColor
>       fade_distance 1
>       fade_power 2
>   rotate <30,30,0>
> camera {
>   location  <0, 0, -3>
>   look_at   0
>   angle 50
