POV-Ray : Newsgroups : povray.binaries.images : Loneliness WIP (85kbu) Server Time
14 May 2026 18:15:01 EDT (-0400)
  Loneliness WIP (85kbu) (Message 1 to 10 of 12)
Subject: Loneliness WIP (85kbu)
Date: 13 Jul 2002 16:12:05
Message: <3d308995@news.povray.org>
An early WIP of my IRTC entry. Trees and grass are created with Giles Tran's
makegrass
and maketree. The flowers are from plantstudio 2, which for those who don't
know is now freeware.
I might add person kneeling in front of the stone. I'll see how the mood of
the scene develops
Gail
p.s. My download of 3.5 just finished, I can finally stop playing with the
system clock
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)///GS
Download 'Goodbye.jpg' (86 KB)
Preview of image 'Goodbye.jpg'
Subject: Re: Loneliness WIP (85kbu)
Date: 13 Jul 2002 16:30:16
Message: <3d308dd8@news.povray.org>
> makegrass
> the scene develops
It's so DARK, even in the parts where the sunlight hits things.. unless
this takes place during an eclipse or you're trying to make it look
strange, I'd make the sun a lot brighter. Try doubling it for a start...
Also, I don't see any radiosity artifacts, so I'm guessing you're using
ambient.. if you have a fairly beefy computer, you might try it with
radiosity.
-Xplo
Date: 13 Jul 2002 16:47:21
Message: <3d3091d9@news.povray.org>
"Xplo Eristotle" <xpl### [at] infomagicnet> wrote in message
news:3d308dd8@news.povray.org...
Tran's
> > makegrass
don't
of
> > the scene develops
Not an eclipse, I'm going to add thick clouds and rain.
> radiosity.
Athlon 1GHz. I've never had much luck with radiosity.
Gail
Date: 13 Jul 2002 16:49:28
Message: <chrishuff-5067C6.15464513072002@netplex.aussie.org>
In article <3d308995@news.povray.org>,
> Tran's makegrass and maketree. The flowers are from plantstudio 2,
> which for those who don't know is now freeware.
It has that flat, low-contrast look that I see on images with high
ambient textures...I can't make out any of the geometry of that brown
wall. Try setting the ambient in all textures to 0 (I use the default
directive for this) and either use a dim light source at the camera
position or radiosity. By putting a light source at the camera and
dropping ambient to 0, you light everything that is directly visible
from the camera but keep the shading effect from having a direct light
source instead of flat ambient illumination.
Also, that grass looks very dark, and a bit too sparse.
Date: 13 Jul 2002 17:16:25
Message: <3d3098a9@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> ambient textures...
I don't know why. Ambient is at the default value
> wall.
It's actually not a wall. It's a ground plane. The grass is limited to a
small
area. The plane will be replaced with an iso later and additional vegetation
added.
OK,  thanks
Gail
Date: 13 Jul 2002 23:26:50
Message: <chrishuff-BB258A.22241213072002@netplex.aussie.org>
In article <3d3091d9@news.povray.org>,
It is much easier to use in POV 3.5 or MegaPOV than in POV 3.1, I've
often found that just the defaults ("radiosity {}") were fine as a first
approximation. Also check out the standard rad_def.inc include.
Date: 13 Jul 2002 23:29:27
Message: <chrishuff-1D0D66.22265013072002@netplex.aussie.org>
In article <3d3098a9@news.povray.org>,
> > ambient textures...
Which I consider way too high...I usually drop it down to nothing.
> > wall.
> to a small area. The plane will be replaced with an iso later and
> additional vegetation added.
Ah, that would explain a little...needs surface irregularities and
direct light to pick out the surface geometry better. An isosurface
sounds like a good idea, a wall might help.
Date: 14 Jul 2002 09:36:22
Message: <3D317E56.AE1030C5@attglobal.net>
Thanks for this great tip!   I have been adding shadowless lights just
about
everywhere but at the camera position to adjust ambient levels.....
Do you recommend using the shadowless option for the light at the camera?
Date: 14 Jul 2002 11:11:11
Message: <3d31948f@news.povray.org>
I'll bear that in mind in the future. I dropped the ambient right down,
brightened and moved the lights and the scene looks much better
(to me at least)
Is there any reason you use default to set the ambient, rather than
global_settings {ambient_light ... }?
Yeah, the plane's just there for now. The iso is SLOW. A wall won't be
necessary
once all the vegetation's in as it'll be too thick (using images created in
Vue d'Espirit on
boxes. Cuts down on the memory requirements)
Gail
Date: 14 Jul 2002 12:14:39
Message: <chrishuff-D286C3.11120414072002@netplex.aussie.org>
In article <3d31948f@news.povray.org>,
Because ambient_light affects all ambient in the scene. Adjusting the
default texture instead lets me override it for specific objects that
need it, like a glowing LED, a neon light, or a computer or TV screen.
I've been doing something similar with diffuse...setting the diffuse
value in defaults and only adjusting pigment color in the textures. I
can then adjust the diffuse value in defaults to control the overall
brightness of the scene...this is pretty helpful with radiosity.
