POV-Ray : Newsgroups : povray.binaries.images : A test render (78kbu) Server Time
23 Apr 2026 05:18:21 EDT (-0400)
  A test render (78kbu) (Message 1 to 9 of 9)
Subject: A test render (78kbu)
Date: 23 Jun 2002 17:16:28
Message: <3d163aac@news.povray.org>
Hi everybody,
    It's been a while since I last posted anything hasn't it? Well, first of
all, I simply haven't had anything worth showing, and second, I've been
super busy. I'm taking a 5 credit class that was advertised (and paid for
as) a 3 credit class. Naturally, the work-load is heavier than I planned
for, and that doesn't leave me much time for playing on the computer.
Believe it or not, I've found myself turning it off after finishing my work,
and getting away from it! :O
    But I digress. This weekend I finally had a chance to do some POVing.
(Oh, how I missed it!) I modelled this pot in Rhino, exported a POV mesh,
and converted it to a mesh2 using Warp's excellent mesh compressor. Then I
applied a texture I had been experimenting with previously, and let 'er
render. This was done in 2 passes, the first taking ~6 minutes (at 512x320),
and the second taking ~35 minutes (at 1600x1000). I also did a little bit of
post-processing in Photoshop to clean up some ugly little artifacts.
    Comments and criticisms are welcome. I hope you like it. :)
Download 'pot_test2.jpg' (78 KB)
Preview of image 'pot_test2.jpg'
Subject: Re: A test render (78kbu)
Date: 23 Jun 2002 17:42:06
Message: <3d1640ae$1@news.povray.org>
I like it! And it's beyond me how you made a beautifully 'melted' surface
with the Rhino interface.. At least to me, Rhino doesn't allow wonders, but
usually complains about what I'm trying to do, even though I follow the
simple toturials! The menus are full of options that fails to work.
- Hugo
Date: 23 Jun 2002 18:17:07
Message: <3d1648e3@news.povray.org>
> I like it!
Great!
> surface with the Rhino interface.
I never said it was easy! It took a lot of messing around to get this. It's
not exactly what I had originally planned either, but I'm happy with it. :)
Yeah, it is a bit difficult sometimes.
Date: 23 Jun 2002 19:09:44
Message: <3d165538$1@news.povray.org>
very nice pot!, suppose this means I will have to dig rhino out and do
something now :)
PGP Public Key
Version: 6.0.372 / Virus Database: 207 - Release Date: 21/06/2002
Date: 23 Jun 2002 21:36:20
Message: <3D16778B.3050601@caltel.com>
Hmm... mysterious. A clean dish, empty except for a ball. A dog thanking
it's owner for a good meal, perhaps?
Nice modeling of the dish. I'm currently frustrated at 3D modelers. You
see people modeling amazing things like heads and whole characters! When
I try to do the same, things don't turn out quite right.... Maybe it's
the tools I'm using (Amapi, HamaPatch, Rhino....).
Realistic lighting you used, too. Nice little touch the radiosity
produced with the slight caustics near the bottom corners of the dish.
Tony[B] wrote:
> Hi everybody,
Samuel Benge
sbe### [at] caltelcom
Date: 23 Jun 2002 22:03:33
Message: <3d167df5@news.povray.org>
> thanking it's owner for a good meal, perhaps?
Um, if you like. I meant nothing by it. :)
Thank you!
I think that unless you move into big name modelers you don't get the power
you need. And even then there is a lot of stuff that you wish you could do,
but that the modeler you're using can't manage (or at least not in a
straightforward manner). This is why studios have to jump around between
several packages to get the job done. :P
I used a simple planar on a sphere, and two lights, nothing fancy... I think
it's the texture more than the lighting that brings out that realistic
touch.
That's where the artifacts I removed were. I used 'smart-blur' to make them
into what you see. Before, they were just ugly bands of light and dark.
Date: 24 Jun 2002 04:18:14
Message: <3d16d5c6$1@news.povray.org>
> I'm currently frustrated at 3D modelers. You see people modeling
> amazing things like heads and whole characters! When I try to do
> the same, things don't turn out quite right.... Maybe it's the tools
I know what you mean, I tried those programs too and none of them worked as
I desired.. But I found something nice! I strongly encourage you to try out
"Wings3d" that is an efficient and easy polygon modeller. I guarantee you'll
be able to use it very quickly.
It still needs skill to model beautiful things (fortunately) and the
principles of polygon modelling is not the answer to everything, but it has
some forces. It's not a replacement for modelling with POV but a nice
additional tool.
The program is freeware and under development. At the moment it's not a
texturing or animation tool, but supports common file formats, and has
direct output to POV mesh2 (via a plugin).. However, the plugin currently
doesn't work with the newest version of Wings3d, so I use an older version:
0.94.1.. You may have a look at: www.wings3d.com and let me know if you have
questions.  :o)
Hugo
Date: 2 Jul 2002 20:40:50
Message: <3D224811.E42CAD35@iki.fi>
"Tony[B]" wrote:
> I applied a texture I had been experimenting with previously
That texture really is neat and realistic. How is it made?
Two passes to first create radiosity data and then render with final
resolution, or for what?
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Date: 3 Jul 2002 01:54:08
Message: <3d229180@news.povray.org>
Why thank you! :) But do note that the "environment" is an important
component of the texture.
> How is it made?
Something like this... (if I haven't changed it since this post...)
#declare LayerA =
texture
 pigment
  planar turbulence 0.2
  scale max_extent(Pot).y
  color_map
   [0.0 rgb <0.50,1,0.50>/12]
   [0.7 rgb <0.30,1,0.50>/6]
   [1.0 rgb <0.25,1,0.75>/24]
 finish
  reflection {0.1 metallic
  metallic
 normal
  bozo warp {turbulence 0.5}
  scale 3 bump_size 1
#declare LayerB =
texture
 pigment {rgbf 1}
 finish
  reflection {0,1 fresnel}
  specular 0.125 roughness 0.01
#declare PotTex =
texture {LayerA}
texture {LayerB}
#declare PotMat =
material
 texture {PotTex}
 interior {ior 1.4}
One pass for radiosity data without reflections at a low resolution, and the
final at a high resolution with reflections.
