POV-Ray : Newsgroups : povray.binaries.images : blurred reflections Server Time
11 Jan 2026 19:56:22 EST (-0500)
  blurred reflections (Message 1 to 8 of 8)
Subject: blurred reflections
Date: 11 Jun 2002 12:43:21
Message: <3d0628a9@news.povray.org>
After some experimenting, I got my blurred reflections to work better,
smoother and faster.  I had been trying to use the "averaged normal" method
with no real success.  I found that what I really needed was averaged
textures with different normals, which worked out just swimmingly.
(assuming the images post in order) The first image has no AA, the second
has AA0.0
In the following images the middle cube uses just one texture with one
'micro-normal', kinda grainy looking. The right-hand cube uses one texture
with averaged normals (15 samples used), not better, in fact, probably
worse.  Left-hand cube (the right solution!) uses averaged textures with
differing normals (15 used, in fact the same normals which were averaged in
the right-hand cube), tons better (IMO).
Also note that the blurred reflection type used here is a radial one at the
centre of each cube.
Thanks for the help aqnd info all.
-tgq
Download 'BRnoAA.JPG' (92 KB) Download 'BRAA.JPG' (60 KB)
Preview of image 'BRnoAA.JPG'
Preview of image 'BRAA.JPG'
Subject: Re: blurred reflections
Date: 11 Jun 2002 12:51:52
Message: <3d062aa8@news.povray.org>
sweet - can you post the source?
PGP Public Key
Version: 6.0.370 / Virus Database: 205 - Release Date: 05/06/2002
Date: 11 Jun 2002 13:06:13
Message: <3d062e05$1@news.povray.org>
news:3d062aa8@news.povray.org...
Sure thing, but I will clean it up first.
-tgq
Date: 11 Jun 2002 13:51:49
Message: <3d0638b5@news.povray.org>
It seems you made the normals very small. Its better to make them very big
and translate them very much. Then you wont need aa at all to make the
blurred reflection look good.
Date: 11 Jun 2002 14:35:33
Message: <3D064768.5030904@caltel.com>
Can you show us an example please?
Samuel Benge
sbe### [at] caltelcom
Date: 11 Jun 2002 15:19:36
Message: <3d064d48$1@news.povray.org>
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3d0638b5@news.povray.org...
Actually I was getting better results with small normals than with big ones,
also with the radial type of blur, large translations would counter act the
radial effect.
-tgq
Date: 11 Jun 2002 16:42:34
Message: <3d0660ba@news.povray.org>
Look through some older Warp or Ron Parker's posts...
Date: 11 Jun 2002 21:31:59
Message: <3D06A901.5020309@caltel.com>
Ah yes, I wasn't actively using POV then.
Samuel Benge
