POV-Ray : Newsgroups : povray.binaries.images : Key WIP Server Time
1 Mar 2026 04:22:22 EST (-0500)
  Key WIP (Message 1 to 8 of 8)
Subject: Key WIP
Date: 6 Jun 2002 00:52:15
Message: <3cfeea7f@news.povray.org>
That focal blur thing has become a key now. Because the key is very
reflective, I'm gonna have to do something about the surroundings. The
lighting needs work to. Maybe I'm gonna use radiosity.
My final goal is to get something that's (almost) like a real photograph.
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Download 'key.jpg' (21 KB)
Preview of image 'key.jpg'
Subject: Re: Key WIP
Date: 6 Jun 2002 05:31:38
Message: <3cff2bfa@news.povray.org>
Cool!
how did you make the teeth on the key?
Gary
Apache <apa### [at] yahoocom> wrote in message
news:3cfeea7f@news.povray.org...
> Apache
> ICQ: 146690431
Date: 6 Jun 2002 06:10:11
Message: <3cff3503@news.povray.org>
"Ace" <ble### [at] icefognet> wrote in message
news:3cff2bfa@news.povray.org...
> Cool!
CSG difference or a prism?
Date: 6 Jun 2002 11:12:40
Message: <3CFF8069.6080907@caltel.com>
Hey Apache, pretty good! I don't have much patience for modeling.
Perhaps to help the key show its reflective properties you can place it
in a room(box) where there is a very bright light_source that has a
fade_power of 2 and a short fade_distance.
> Apache
> ICQ: 146690431
Samuel Benge
sbe### [at] caltelcom
Date: 6 Jun 2002 14:29:01
Message: <3cffa9ed@news.povray.org>
The key is completely csg, except for the rough surface which is an
isosurface.
Apache
ICQ: 146690431
Date: 6 Jun 2002 17:37:18
Message: <3cffd60e$1@news.povray.org>
I put a big version (1152x864) on the web:
http://geitenkaas.dns2go.com/experiments/key_1152x864_progressive.jpg
Apache
ICQ: 146690431
Date: 21 Mar 2014 13:55:01
Message: <web.532c7bf557143d40e35150140@news.povray.org>
> Apache
> ICQ: 146690431
can i borrow your povray source code for the key demo
Date: 21 Mar 2014 15:04:26
Message: <532c8d3a@news.povray.org>
>> Apache
>> ICQ: 146690431
For the focal blur using all default values as a starter:
camera{location Your_Location point_at 0
aperture 0.1
blur_samples 7
confidance 0.9 //default
variance 1/128 //default
focal_point <0,0,0> //default
Alternative requiring the use of version 3.7:
aperture 0.1
blur_samples 7 24
// Minimum number of samples and Maximum number of samples.
bokeh{pigment{...}}
Start with the defaults.
aperture and blur_sanmples default to zero, turning the feature OFF.
Change aperture according to the mood of your scene. It's value is
dependent on the scale used for your scene. Keep it small for general
cases and very small for most outdoors scened. Use a larger value for
closeups and images of small objects. A large aperture often make your
scene look as if it was a miniature.
If the image is to grainy, increase blur_samples as needed. If you use
version 3.7, you can force POV-Ray to use a minimum number of samples by
using the two values syntax. Very usefull in some cases.
If needed, increase confidance or decreast variance. This will increase
the likelywhood that you'll use the maximum number of blus_samples, but
will also increase the rendering time.
Usualy, focal_point should be the same as your look_at point, but it's
not needed. I recommend that you set focal_point close to your look_at
if they are different.
The bokeh feature is usefull to simulate the actual shape of an
objective, but can be any pigment or an image_map (preferably monochrome).
