POV-Ray : Newsgroups : povray.binaries.images : Problem with media (giraffe.jpg 16.70 Kb) Server Time
26 Mar 2026 18:28:48 EDT (-0400)
  Problem with media (giraffe.jpg 16.70 Kb) (Message 1 to 7 of 7)
Subject: Problem with media (giraffe.jpg 16.70 Kb)
Date: 31 May 2002 15:49:29
Message: <3cf7d3c9@news.povray.org>
Hi all:
I'm working in the current IRTC stills topic and everything works fine till
now except for the media in this model.
I think fire looks realistic enough, except for that strange "yellow tail".
The clouds are four semitransparent planes (all with the hollow keyword).
I've tried another possible combinations (the Gilles' fastclouds.inc file
and the fastsky.inc file from Rune).
If I use the clouds (anyone of them) this yellow tail appears. If I do not
it doesn't appear.
Assumed Gamma is 1
The giraffe and the media container are bicubic patches (from hamapatch).
The scene is made in Moray (z is up) and rendered in the last pov candidate.
The material is as it follows:
#declare jirafa_fuego_txt =
   material  // jirafa_fuego_txt
      texture
          pigment
            color rgbft <0.0, 0.0, 0.0, 1.0, 1.0>
         finish
            ambient 0.0
            diffuse 0.0
      interior
         media
            samples 10,10
            emission rgbf <1.0, 0.7604, 0.0, 0.0104>
            scattering
               1 // isotropic scattering
               extinction 0.2
            density
               gradient z
               density_map
                  [0.0
                     bozo
                     color_map
                        [ 0.0     rgbft <0.0, 0.0, 0.0, 1.0, 1.0> ]
                        [ 0.370107  rgbft <0.0, 0.0, 0.0, 1.0, 1.0> ]
                        [ 0.494662  rgbft <1.0, 0.0104, 0.0, 0.0, 0.0> ]
                        [ 0.740214  rgbft <1.0, 0.0104, 0.0, 0.0, 0.0> ]
                        [ 0.975089  rgbft <1.0, 0.718733, 0.1354, 0.0104,
0.0104> ]
                        [ 1.0     rgbft <1.0, 0.0104, 0.0, 0.0, 0.0> ]
                     turbulence <0.0, 0.2, 0.5>
                     phase 2.79
                     triangle_wave
                     scale  <1.0, 0.1, 0.5>
                  [0.5
                     gradient z
                     color_map
                        [ 1.0     rgbft <0.0, 0.0, 0.0, 1.0, 1.0> ]
                  [1.0
                     gradient z
                     color_map
               turbulence <0.0, 1.0, 0.2>
               ramp_wave
               scale  <20.0, 20.0, 40.0>
               translate    <0.0, 0.0, -5.0>
      scale  <0.2, 0.8, 0.8>
      rotate -20.0 * x
Can someone help me with this?
Thanks in advance.
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Download 'giraffe.jpg' (17 KB)
Preview of image 'giraffe.jpg'
Subject: RE: Problem with media (giraffe.jpg 16.70 Kb)
Date: 31 May 2002 16:15:50
Message: <3cf7d9f6@news.povray.org>
Sorry, 2 brackets where lost in the copy process (one after material and
another after texture).
This has nothing to do with the question asked in the previous post, the
problem is the same.
Here is the image without cloud for comparission.
Bye
Txemi Jendrix
Download 'giraffe2.jpg' (13 KB)
Preview of image 'giraffe2.jpg'
Subject: Re: Problem with media (giraffe.jpg 16.70 Kb)
Date: 31 May 2002 16:57:10
Message: <3cf7e3a6$1@news.povray.org>
> appears. If I do not it doesn't appear.
Could it be max_trace_level is set too low? It's a nice giraffe, from what I
can see on this distance. :o)  Looking closely, I think there's a problem
with the back-left leg; it seems to be cut similar to the yellow tail..
Maybe something intersect with the objects, or you specified bounding boxes
that cut the object.
Have you tried the scene from other camera locations?
I agree this is strange...
Hugo
Date: 31 May 2002 17:01:36
Message: <3cf7e4b0$1@news.povray.org>
I see the artifact on the version without clouds, too, it's just darker.
I suspect the container object isn't closed.
 - Slime
[ http://www.slimeland.com/ ]
Date: 31 May 2002 20:21:22
Message: <3cf81382@news.povray.org>
3cf7e3a6$1@news.povray.org...
I don't think so, its at 255.
> It's a nice giraffe, from what I can see on this distance. :o)
The giraffe is a free mdl model (Hash Animation Master) from
http://www.eggington.net/Hash/Models/
imported in hamapatch (even though I spent 3 hours closing patches that were
imported as 5 points patches).
No, it's a question of perspective. Perhaps you are refering to the actual
giraffe tail that is behind the back left leg.
boxes
any bounding box neither.
Yes, and rotated the giraffe to different angles, but the yellow tail it's
still there.
Me too. Thank you for your interest Hugo.
Bye.
Txemi Jendrix
Date: 31 May 2002 20:47:25
Message: <3cf8199d@news.povray.org>
3cf7e4b0$1@news.povray.org...
Now that you say it, I see it too.
You are right. I've opened the hamapatch file and the end was open (even
though it is a four point patch).
Should have checked it by myself before posting. Now it looks fine.
Thank you very much for your help (there is nothing like these newsgroups
Bye
Txemi Jendrix
Download 'giraffe3.jpg' (27 KB)
Preview of image 'giraffe3.jpg'
Date: 31 May 2002 21:37:10
Message: <3cf82546$1@news.povray.org>
I love it when things go like this.... :-)
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
